Question about Casio FX-115ES Scientific Calculator
I cant use the rec on my calculator - Casio FX-115ES Scientific Calculator
How do i calculate Rec on fx-992s casio calculator?
Rec? Conversion from polar to rectangular coordinates ? You need and a radius (length) and an angle (Rec (r, theta)). Make sure the angle unit is the one you want: degrees or radians.
Dec 27, 2016 | Casio Fx-992s Scientific Calculator
I need to convert the rectngular form to polar form , so how can i do that ?
In Run screen, Press OPTN, Press F6> repeatedly until you see the ANGL TAB. Press F6> again (once or twice). You will see the TAB Pol( and Rec(
To convert from Rectangular coordinates to Polar press POL(, type in the x and y coordinates then EXE
Example: F1: Pol(1,1) gives (1.314213562, 45)
F2: Rec(square root (2), 45) gives (1,1)
Make sure the angle unit is set to the one you need (degree or radian).
Apr 19, 2012 | Casio Algebra FX 2.0 Calculator
Casio fx 82 au plus convert polar to rectangular
To convert from Polar to Rectangular
PRESS [SHIFT and -Rec] then enter the coordinate and angle
e.g. [SHIFT and -Recl]
Rec(15,0)=
r=15
0=0
Jun 18, 2011 | Casio FX-115ES Scientific Calculator
I am a casio fx-82MS user. i would like to know how i can convert polar form to rectangular form in my calculator
Press [MODE] and select [1:COMP]
Press [SHIFT][MODE] and select [3:Deg]. You can also use rad if the angle you are given is in radians.
To start the conversion
Press [SHIFT][-] (Rec) screen displays Rec(
Key in the radius r , ex: 3 screen displays Rec(3
Press [SHIFT][)] (,) to enter comma separator Rec(3,
Key in the angle in degrees, ex: 57.3; screen displays Rec(3,57.3
Press ) to close parentheses; screen displays Rec(3, 57.3)
Press [=]
Screen displays
Rec(3, 57.3)
X=1.620720961
Y=2.524532346
X and Y are the values of the coordinates.
If angle is in radians, [SHIFT] [MODE][4:Rad] the command
Rec(3, Pi) gives X=-3, Y=0
I just realized that your question pertains to the FX82MS but is listed under the FX115ES (That is quite a difference) So my answer above does not concern you but I will leave it as is should anyone need the answer for the FX115ES.
Look at the enclosed screen capture for the FX82MS
Nov 13, 2010 | Casio FX-115ES Scientific Calculator
How to change polar form to rectangular form by calculator?
Use the Rec function (shift of the - key).
Rec(r,t) converts a polar value of magnitude r and angle t in the current angular mode. The real value is assigned to X and the imaginary value is assigned to Y.
Use the Pol function (shift of the + key) for the reverse.
It's on page E-37 of the manual. If you've misplaced your manual, you can download a new one from http://www.casio.com/support/manuals
May 28, 2010 | Casio FX-115ES Scientific Calculator
How can i enter a polar form number with angle to convert into a rect form
how can i enter a polar form number with angle to convert into a complex numbe(a+bi)
Apr 28, 2010 | Casio Algebra FX 2.0 Calculator
How do you use the pol and rec
To avoid errors make sure that the angle unit is THE ONE required by your problem. To verify or to change the angle unit press [SIFT][MODE] and select [3: Deg] for degrees, [4:Rad] for radians, or [5:Grad] for grads.
Convert from rectangular to polar
[SHIFT][+] (Pol) . Screen displays Pol(
You enter the X-coordinate, and the Y coordinate separated by a comma, then you close the parenthesis and press [=].
Exemple: Polar coordinate of the point (1,1)
Pol( 1, 1) gives
r=1.414213562 (square root of 2)
θ=45
Here is how you enter it
Press [SHIFT][MODE][2:LineIO]
[SHIFT][POL] 1 [SHIF] [,] 1 [)] [=]
The screen displays
Pol(1,1)
r= 1.414213562
θ= 45
Convert from polar to rectangular coordinates
Rec ( radius, angle) =
Exemple: Recatngular coordinates of (r=3, θ=60°)
[SHIFT][Rec] 3 [SHIFT][,] 60 [ ) ] [=]
The screen displays
Rec(3,60)
X= 1.5
Y= 2.598076211
Jan 19, 2010 | Casio FX-115ES Scientific Calculator
Can you show how to convert pola to rectangular o
Pol( 1, 1) gives
θ=45
The screen displays
Pol(1,1)
r= 1.414213562
θ= 45
The screen displays
Rec(3,60)
X= 1.5
Y= 2.598076211
Hope it helps.
Nov 14, 2009 | Casio FX-115ES Scientific Calculator
How to convert polar to rectangular form
Press [=]
Screen displays
Rec(3, 57.3)
X=1.620720961
Y=2.524532346
Hope it helps
Oct 18, 2009 | Casio FX-115ES Scientific Calculator
Casio FX-115ES Scientific Calculator Logo
81 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
