SOURCE: The pilot light has gone out on an old Vulcan gas
You probably need to replace the thermocouple before you will be able to get it lit.
SOURCE: pilot lights but won't stay
Most common cause of pilot light problems is air movement. If your space heater exhausts gas through the roof, ensure the cap is on and level. If not, outside air movement will blow out the pilot. If you do not have an exhaust gas duct, check that the unit is positioned so that it does not blow air back onto itself from walls, furniture, etc, and ensure no other devices that move air are aimed towards the unit. The unit also needs to be placed away from central ducting, including return vents.
Hope this helps!
SOURCE: we have a Vulcan Ultra high efficiency gas ducted heating
Gas ducted central heater won't switch on all of a sudden
SOURCE: I have purchased a house
you have air in the gas line , the pilot being so small it would take ages to come through , you need to purge the line to get the air out , se if you can undo the pilot line to pruge it
SOURCE: I have moved into a
Hello, The
first sign of trouble with your water heater's pilot light is usually a
cold shower. Your heater's pilot light allows the burner to cycle on
and off while maintaining the water in the tank at a constant
temperature. When the pilot light goes out for any reason, the
thermocouple closes the burner's gas supply valve to prevent gas
escaping and filling your house. When your pilot will not light or does
not remain lit, you might be able to save the price of a service call
by taking a few minutes to troubleshoot the problem.
Here are the solution below to solve the problem on your on the mater of do it your self one after the other (step by step).
Difficulty: Moderately Easy
INSTRUCTION
Thank you and thanks foe using fixya.
