Konica Minolta bizhub 250 All-In-One Laser Printer Logo
A
Anonymous Posted on Jul 14, 2014
How do I fix trouble code c- 0204 on my bizhub C554e Photocopier machine?
Adorjani Laszlo
Level 3:
  • Konica Minolta Master 1,316 Answers
  • Posted on Jul 21, 2014
Adorjani Laszlo
Level 3:
Answers
1316
Questions
Helped
457076
Points
2563
Tray 2 feeder up/down abnormality.The paper feed tray 2 upper limit sensor is not blocked even after the lapse of a given period of time after the lifting motion has been started.Check the sensor and the sensor actuatos.
3 Related Answers
Anonymous
  • 145 Answers
  • Posted on Oct 12, 2008
SOURCE: Bizhub Di1610fp
C0500 code that is fuser.try reset this one first by powering machine on while holding down STOP BOTTON ON THE OP PANEL
hope that help
chip_reset
Konica Minolta Error Codes and Solutions
  • 210 Answers
  • Posted on Aug 26, 2009
SOURCE: My bizhub has an error code of C0501
C0501 it is a trouble related with the Fusing Unit. Try to power it up with the STOP button pressed. If not, you may need to change your fusing unit.
xeerie
Zaheer Ahmed
  • 347 Answers
  • Posted on Oct 20, 2010
SOURCE: Konica Minolta bizhub 250 code 0204
The code is an error code, it means your copier bizhub 250 is having some problem in the LCT.large capacity tray the last tray.its not opening or may be malfunctioned.
Konika minolta c554e error code C-3102. HOW DO YOU FIX THIS.
1 Check the fusing unit for proper installation and correct as necessary.
2 Check the connector between M3-PRCB CN2 for proper connection and correct as necessary.
3 Check the connector of M3 for proper drive coupling and correct as necessary.
4 PS37 I/O check, sensor check.
5 M3 operation check PRCB CN2-9 (REM) PRCB CN2-12 (LOCK) bizhub C554 22-J bizhub C454 21-J.
6. Replace M3.
7. Replace the fusing unit.
8. Replace PRCB.
Konica bizhub 283 photocopier error code c9401
FIRST, if this code comes back. Have a technician look at it the exposure lamp the bright light under the glass is bad or the board controlling it.
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Bizhub c554e error code c4801
MFP detects simultaneous replacement of multiple boards. YOU REPLACED board and did not follow the service manual
Do not replace the printer control board and the SSD board at the same time. The backup data is lost and image failure may be
caused.
Why do i get a error code c1105 on my bizhub c554e and how do i fix it
Sorry your having trouble. Your code suggest you have an optional KM FS-534-535 finisher attached to your copier. The code is triggered by an internal part within the finisher and should be thoroughly inspected only by a certified factory trained service technician. I would suggest you contact your local repair company.
Attempting to resolve this issue on your own could produce negative results.
1helpful
Error c3452
Power off the machine wait ten seconds then holding the down the clear/stop button power on the machine. should clear the code if the code comes back replace the fusing unit the hot part!
1helpful
3helpful
6answers
Konica Minolta bizhub 163 Display M2. and not functioning Photocopy. Please sugest me ?
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
We have a problem Konica Minolta Bizhub C352 error code C-0204, our machine work properly for months years, we don't have work yesterday, but when we open our machine today the error affairs. we try to...
Check out the user guides for this printer.
CLICK HERE!
There has to be something about a Hard reset that might could fix your problem.
Hope that helps, give thumbs up please!
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
