Question about Samsung Clx-6250fx Multifunction Laser Printer With Copy/fax/print/scan Samsun
Why error lsu in samsung 6250fx appears in the printer screen?
Tony Stark
  • Samsung Master
  • 675 Answers
You must enter the error code too to get the exact solution.
Posted on Jul 14, 2014
5 Related Answers
Anonymous
SOURCE: lsu error pour samsung scx-4100
Please kindly help me to sole the problem Lsu of my printer samsung scx-4100
thanks
Posted on Sep 20, 2008
lyzias morato
  • 1566 Answers
SOURCE: LSU error in Samsung 4725FN all in one printer how
The LSU error stands for Laser Scanner Unit error. The probable cause/s:
The Polygon motor in the LSU does not rotate.
The LSU’s laser beam is functioning properly.
What you can do:
Try to unplug the machine for a couple of minutes or maybe a little longer and then plug everything back in. Power on and then test.
Posted on Feb 09, 2010
nsvaas
SOURCE: engine LSU error printer model samsung ML2150
how can over come from LSU error problem in samsung all in one machines
Posted on May 08, 2010
mariolands
mariolands
  • 2296 Answers
SOURCE: Samsung Printer SCX-4100 LSU Error
Laser Scanner Unit or LSU is what writes to the surface of the drum. The glass above the cartridge in the machine may be dirty. The mirror motor in the LSU could be bad or needs to be cleaned to spin better. The Laser diode may be faulty.
This is not a user-serviceable issue. You will need to contact Samsung for service. You can do it online via Samsung website or contact the vendor to see who will they appoint to service the printer to, especially if it is still under warranty.
Posted on Jan 27, 2011
Trojaner
  • 111 Answers
SOURCE: my printer is samsung scx4300
This is Laser Scanner Unit error and this is probably cause if the polygon motor in the LSU does not rotate.The LSU's laser beam is functioning properly.You can try unplugging the machine for 3 minutes and plugging back in before you do anything else.If this does not fix it you will need to have it serviced by samsung.
Posted on Apr 27, 2011
Missalignment of printer toners
Hi, you mean you could see the outline of the colors?
Feb 27, 2014 | Samsung CLX-6250FX Color Laser MFP
I need a manual for the Samsung printer called 6250FX ( it has CLX before the numbers, also ).
http://www.samsung.com/uk/consumer/print-solutions/print-solutions/colour-multifunction-printer/CLX-6250FX/SEE/index.idx?pagetype=prd_detail&tab=support
Jun 13, 2011 | Office Equipment & Supplies
Samsung SCX4200 laser Printer LSU error showing in screen
This is not a user-serviceable issue. You will need to contact Samsung for service. You can do it online via Samsung website or contact the vendor to see who will they appoint to service the printer to, especially if the printer is still under warranty.
Dec 28, 2010 | Samsung SCX 4521F All-In-One Laser Printer
How to troubledhoot the LSU error on samsumg
repalce laser unit or check menu # 1931 lsu mirro test
Aug 03, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Engine LSU error printer model samsung ML2150
Jan 21, 2010 | Samsung ML-2150 Laser Printer
LSU ERROR MESSAGE ON little screen when photocopying
What you can do:
Mar 11, 2009 | Samsung SCX 4521F All-In-One Laser Printer
LSU Error
LSU (Laser Scanning Unit) is a device inside the printer that create images on the drum.
If you see LSU Error on the display, it is indicating that there's a problem with LSU unit.
  • Unplug the power cord and plug it back in.
  • Check if the printer makes any humming noise.
If the problem persists or does not make any noise, LSU needs to be replaced.
If your unit is under warranty, please contact our tech support at 800 - 726 - 7864.
Otherwise, please find nearest Samsung Authorized Service center from the link below.
Dec 06, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Samsung Clx-6250fx Multifunction Laser Printer With Copy/fax/print/scan Samsun Logo
94 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
