Question about Samsung Galaxy S GTI9000 Smartphone
Note 2 wont charge - Samsung Galaxy S GTI9000 Smartphone
Are there battery recharging problems with Galaxy Note 10.1?
Possible both try charging unit using a friends 10.1 charger if same results in battery been partly charged. The answer is yes its the battery
Oct 11, 2014 | Samsung Galaxy Note 10.1"
My samsung galaxy note wont charge and flashes?
Firstly check to see if your charger is giving out a voltage. If so you may need to have the tablet repaired
Sep 12, 2014 | Samsung 16GB Galaxy Note 8.0 Android 8"...
Galaxy note gt-n8013 wont turn on or charge
If you disturbed the tablet part way through flashing or it became unresponsive during the process you have probably bricked your tablet.
Mar 19, 2014 | Samsung Galaxy Note GT-N8013 10.1" 16 GB...
02 altima charnging
The charge wire that goes from the alternator lug to the power box may be bad. Inspect it carefully for damage or corrosion.
Nov 12, 2017 | Nissan Altima Cars & Trucks
Acer aspire 6920 11.1 v battery work but 14.8 v wont charge why is this
Check model numbers, I had this problem with apple, to of the same laptops two differnt batteries
Apr 03, 2017 | Acer Aspire 6920 Notebook PC
My acer note book charges but screen wont come on
1. It may be the ram sticks are not secure or seated properly.
2. It may be that the luminous tube that give the LCD it light has failed. In any instance you will need to have your laptop serviced by a tech. There could also be a bad inverter. This may be on the motherboard itself if so then a mother board needs replacement.
May 01, 2010 | Acer Aspire 3680 Laptop
Not charging, green light on cord is lit up but wont charge
cthom10388
In regards to your notebook not charging this could be one of 2 things if your AC Adapter is showing a green light. Ether your battery is bad or there is something wrong with the charging mechanism.
If you are still in warranty I would call Acer about getting a replacement battery and/or motherboard because the charging mechanism is part of the motherboard.
Note another test you can do if you know someone that has the same model of Acer you can try your battery in there system. If their system charges the battery then you know the problem is not with the battery.
Hope this helps
Issken
Jan 11, 2010 | Acer Aspire 5315 Notebook
Zen is dead
Sounds like a battery problem - either the battery is totally dead or just needs recharging - note that when the battery totally loses its charge, I believe it is sometimes not possible to recharge it using the usb port and software method (NOTE you MUST have the software installed and running for it to charge this way).. you may have to charge it using the connector to the power adapter.
Sep 21, 2008 | Creative Labs Zen Touch MP3 Player
Dell batteries.
Its time change ur batteries
Aug 16, 2008 | Dell Inspiron 1501 Notebook
Creative zen v plus
You could try the back usb port, mine doesn't charge on the front port It needs 2.5vdc?
Aug 26, 2007 | Creative Labs ZEN V Plus MP3 Player
Samsung Galaxy S GTI9000 Smartphone Logo
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
John Tripp
John Tripp
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
