Question about Fisher and Paykel DEGX1 Electric Dryer
Fisher & paykel dryer ed 65
Hi i have the same problem all the lights come on i push start and it just beeps but does not start i have tried what was suggested but still nothing any other solutions before i buy a new one thx john
5 Suggested Answers
localwonder
Michael Masters
  • 6784 Answers
SOURCE: The dryer won't run. Dry, extra dry, and coold down process lights are lit.
Hi, the lights are signaling a control fault the is concerning the logic sector of the control board/timer. you will need to make sure that the wiring harness is connected to all points and it should be in good condition. if there are no apparent issue with the wiring harness, replace the control.
Posted on May 29, 2009
Anonymous
SOURCE: Fisher & Paykel Auto Sensor Dryer stops & beeps constantly
Hi emkboyce
my Fisher Paykel auto sensor dryer keeps stopping and beeping, i have to stop it and and re start.
I had the same problem. I took it off the wall and vacuumed up all the lint from everywhere including around the back and including taking off the back and vacuuming everything I could reach inside. I then used a damp cloth to get rid of the rest of the lint/dust.
I thought I was wasting my time but guess what, the problem has gone.
Posted on Nov 08, 2009
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: hi i have an old fisher & paykel whiteway 405
I have never worked on one of these but I have a manual I can give you. I imagine it is a bad roller or idler.
Happy holidays DEGX1 repair manny
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 04, 2009
Anonymous
  • 69 Answers
SOURCE: The power comes on but when the start pressed it
Sounds like problem with door switch not making contact. To test: open dryer door and locate small slot in cabinet ( located a few inches below bottom of plastic control panel). Poke a small screwdriver into this slot- you should hear a small click- this is the door switch. Whilst holding switch in with screwdriver, press the start button and you should find dryer will start. Now check on the dryer door- there should be a plastic shaft that goes into this slot when door is closed- sometimes this breaks off. If shaft is not broken, problem lies with the switch inside cabinet- not easy to access for DIYer, as drum needs to be removed.  F+P have a lot of problems with the door switches not making contact, but is generally a relatively inexpensive repair if you call for service. Good luck!!
Posted on Mar 10, 2010
Anonymous
SOURCE: Fisher & Paykel ED56 not working
Replace (repair) the exhaust sensor this looks like a transistor with the middle leg cut off. it is situated below the lint filter but can only accessed by removing the back panel, top panel (or rear screws to allow the removal of the drum). drum and then front panel to remove the connector from the mainboard. If you follow the exhaust tube once the back is off you will see a single phillips head screw that is the sensor. check the wires to the circuit board are not broken or dry joints or just replace it. sorry i had a spare machine i scavenged from to fix my problem so i dont know where to buy new.
Posted on Apr 09, 2010
Fisher paykel dryer ed56
Could be the door switch or temp sensor. To check the door switch put pressure against the door and see if it stops. Check the slot the door hits to see if there is anything loose in there.
Jul 20, 2013 | Dryers
Fisher and Paykel GWL11 Top Load Washer starts but drum won't turn, it twitches and beeps then turns off with solid beeps
Hi ken
Can you turn the bowl & agitator by hand.
If it can't turn by hand, Your seal & bearings need replacing.
Feb 01, 2013 | Fisher and Paykel GWL11 Top Load Washer
I have a fisher & paykel 058k, when you push the power button nothing happens, no lights on the panel light up
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 13, 2011 | Fisher Paykel EcoSmart GWL15
I have a fisher and paykel smart drive 5.5 that will not sart filling withwater. All the lights are on and the hoses and filters are not clogged
Hi just found your posting.Do you still require help?Sounds like a lid switch fault to me.Does the machine beep when you push the start button.Please reply for further help.Looking forward to your reply.
Oct 09, 2010 | Fisher and Paykel Fisher & Paykel Washer
Hi emkboyce
Sep 30, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher & Paykel front loader dryer ED56AU
What about the lint sensore, it may be faulty, sending a signal of a fire hazard.
Aug 11, 2009 | Fisher DEIX2 Dryer
My fisher and paykel dryer ( mod# ED56 ) wont start, power is on
I had this same problem with my Dryer. It is making the few quick beeps because it thinks the door is still open. Near the bottom of the opening to the dryer there is a sensor switch that gets pushed in when you shut the door. Try holding the switch in with a knife or something and then start the dryer with the door open to check if that is the problem.
After i did this, i closed the door and my dryer started as normal.
Aug 11, 2009 | Fisher and Paykel DEGX1 Electric Dryer
May 29, 2009 | Fisher and Paykel DEGX1 Electric Dryer
ED 56 FISHER AND PAYKEL WILL NOT START
could be the door interlock is not functioning therefore prventing the start
Mar 11, 2009 | Roper REX3614KW Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
137 people viewed this question
Top Fisher and Paykel Dryers Experts
Nathan Van Boven
Nathan Van Boven
Bill Eager
Dennis Boxerman
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
