Wont print
SOURCE: resume button
What is the exact error message that comes up, and how do you fix it before pressing the "Resume" button? My normal errors with this printer is either no ink, no paper, or paper jam--once the error is corrected, I press the "Resume" button (on the right of the 2 buttons) once only.
I am not too familiar with the flashing error code, I will need to get back to when I find an answer to that. If it is a new print head,
As for a new printer, it depends on many factors:
(1) What you use the printer for?
(2) Do you need color printouts? If not a monochrome laser usually has the lowest cost per page, albeit a greater initial cost of the printer.
(3) Do you use genuine Canon ink cartridges, a generic brand, or refill? I have used generic ink on my i560 for a number of years with no problem
Ishibishi
SOURCE: canon i550 printer stoipped printing
My cannon printer no longer responds to any commands. I get 4 yellow blinking lights and then 1 green blinker.
SOURCE: Canon iP1800 printer,flashing orange light under the green 'on'
First off, How many times does it flash organge before it goes to green?
two: out of paper
three: paper jam
four: Ink has run out
Five: FINE cartridge cannot be found
Seven: FINE Cart. not installed in correct position
Eight: Ink absorber almost full
Count how many times it flashes. Then get back to me
SOURCE: flashing 3 times orange then green?
4 step to Reset waste counter CANON PIXMA iP 1500
STEP 1:- Disconnect printer from AC power(unplug it from all source of power supply leave it for 5min then back after))
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
SOURCE: Left hand light flashing orange and printer wont
Check the following:
Make sure you have removed the seal on each cartridge.
Turn of Printer, open all shutters, front and back and close them firmly, firmly.
Make sure there is no paper jam.
Usually these are the immediate causes of this kind of scenario.
Then try to print again.
If
you need more help come back.
Post
/ thumbs / testimonial are welcome!
