SOURCE: Bottom freezer handle
At both ends and actually inside the ends of the handle, are small metal brackets that are attached to the door face by a single screw.
You access the screws by pulling the plastic plugs, using a very small and thin flat bladed screw driver.
My handle was loose but hadn't come off on it's own. But I couldn't get the handle to fully tighten.
My fix was to wrap each end bracket with a couple layers of electrical tape (not covering the screw hole) and reattached the handle.
It is now very tight, as it should be.
SOURCE: cubic feet?
Most refrigerator models with two digits, the rest letters, the digits stand for the cubic foot capacity of the refrigerator. In you case, 23 cubic foot model.
SOURCE: amana arb1917cc fridge not cooling no sounds from
Good day,
If the lights work, and nothing at all is running, then it is either the defrost timer stuck in defrost, or the main thermostat in the freezer compartment has failed.
Check the timer first. With the freezer control in the freezer compartment set to at least 4 or higher, look for a small hole in the fresh food compartment. It is in the roof (top) of the compartment almost half way back.
With a small screw driver, turn the shaft of the timer clockwise at least a 1/4 of a turn. If it starts, then the timer is bad and needs replaced.
If no luck then it would be the thermostat in the freezer compartment that failed.
P.S. As with all machines, a broken wire could be the problem but on your model, is extremely rare.
SOURCE: I'm trying to find out
This is a tip that I wrote and a couple of paragraphs down it tells you how to figure the cubic feet of your unit...
New Refrigerator Size or Refrigerator Cubic Feet
http://www.fixya.com/support/r4326731-new_refrigerator_size_or_refrigerator
heatman101
