Question about Frigidaire Gallery GLEFM397DS Electric Kitchen Range
Why do my top burners do not work, but oven and inicator lights and clock work
Frigidaire
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon Friend, this is Z. I am happy to assist you!
I understand the burners on your Frigidaire range are working, however you are having trouble with your oven. Do you have an electric or gas range? Can you elaborate prior to your problems any other symptoms or specific error codes before having this issue? Also, may I have your model number please? The serial tag, which lists your model number, is typically located in the storage drawer, on the right side. With this information I can assist you better in pinpointing the problem. Thank you!
Posted on Jul 18, 2014
5 Related Answers
Anonymous
  • 135 Answers
SOURCE: Stove/oven gets hot then shuts off
Shut the breaker off! These are the exact symptoms that a tenant of ours reported for their range. I went to check the range and found that one of the power wires on the terminal block in the back of the range was burning itself up. It had actually started a small wire fire. You need to pull the range out of it's hole and unplug it. Remove the panel in the back above where the cable goes into the range. Examine the power wires and terminal block carefully, because I bet you'll find one of the wires is burning up and needs to be repaired. Please write back and let know what you find.
Posted on Aug 09, 2007
reg501
Richard
  • 413 Answers
SOURCE: The indicator lights and clock
From what you are describing, the power to your stove is incorrect. The diagram indicates the voltages that should be present at the receptacle, I suspect one of the 110 volt legs is bad at the receptacle or circuit breaker. The clock operates on the good 110 volt leg. The burners need both 120 volt legs to be good because the burners and oven need 220 volts to work.
Posted on Jul 11, 2008
appldoctom
Thomas Malailua
  • 311 Answers
SOURCE: Stove Top won't heat
clock works because its only 110 volts.all else is 220.as a repair man the firstplace i would check is the cord.[power off]why there first the installers dont know how important it is for those cord screws to be very tight.consequintly the leave them looseish,and thats where they burn.if thats ok.make sure you have 220 there at the cord.God bless you,tom
Posted on Jan 02, 2009
Anonymous
  • 317 Answers
SOURCE: burners abruptly stooped working on top of the stove
check electrical panel of your house and make sure both breakers are in the on possition ..
Posted on Jan 04, 2010
JEFF SIEGEL
  • 311 Answers
SOURCE: Clock, oven, top middle section of stove does not light up.
The control is bad here.
Posted on Jul 10, 2010
My stove is a GE and everything works but the burners and oven.
check your breakers everything you said means not enough voltage
Apr 05, 2014 | GE Stove/Oven/RanSurface Burner Knob -...
Whirlpool oven designerstyle
Most likely the control / clock has gone bad or possibly a burnt or loose wire connection
Nov 10, 2017 | Whirlpool (ET8FTEXSQ) Top Freezer...
Oven and elements not working,
the oven and burner relay that supplies power to the bake/broil/top surface units is bad or the signal to latch this relay is missing from the control panel
Jun 03, 2012 | Moffat Ovens
My oven clock does not work so my oven does not operate, the top burners are fine and the oven light works so what is wrong with the oven
its probebly a problem with the main pcb.you cn check if you have voltage to the clock if you do it needs to be replaced.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Mar 09, 2010 | Kenmore Ovens
My jennair burners ,fan and oven light work but
Replace the clock first(electric control) then test the oven it could be that it's why the oven does not work.
Jan 13, 2010 | Jenn-Air JES9860 Electric Kitchen Range
After running the self-clean feature on my 21 year old Beaumark stove all of the indicator lights (oven, burners)are not working. The clock (not digital) is not working either. Oven and burners are still...
you may have a temp thermo on the back or the top of oven . hi tempt would have shut off electrical . should have shut the oven off also / wiring in top may be faulty. now if the top burners are working but the clock & oven are not then you have a saftey thermo out . you may need to repl with new one . some ary resetable. take the old one to a appliance parts co . so they can read the tempt,s on it ,. should be able to match .. mm
Nov 20, 2009 | Cooktops
Kenmore Range
Try just unplugging the unit for about 5 minutes. That will reset the clock and hopefully fix the problem. If not you probably need to replace the clock.
Nov 15, 2008 | Kenmore 46564 / 46565 / 465 / 6646569...
The indicator lights and clock on our glass top slide in stove work, but the burners and oven do not heat
Jul 11, 2008 | Frigidaire Kitchen Ranges
Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
66 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
