Question about Xerox DOCUMATE 510 Flatbed Scanner
XEROX DOCUMATE 510
WONT PICK UP PAPER FROM ADF. HAVE TO PUSH THE PAPER IN SO ROLLERS CAN GRAB PAPER.WHAT CAN I DO?
Posted by dmo2 on
Scanner Helper
    Scholar:
    New Friend:
  • 34 Answers
Hello.
I am a Support Engineer with Xerox Scanners.
There would have been an extra pad in the original box that the scanner came in. If you no longer have this pad, you can order the maintenance kit here. This kit will also include the necessary components to clean the feed rollers.
If the feed rollers are worn out, you will need to have the scanner serviced.
Please contact us to discuss your service or replacement options by calling 800-648-0410.
Regards,
Xerox Scanners Support
Posted on Sep 28, 2012
Rick Kasper
    President:
  • 2,072 Answers
The rollers and retard pad need replaced.
The rollers are self explanitory, the retard pad is so named to retard the feed of multiple sheets of paper.
That is your problem.
Posted on Feb 21, 2008
Documate error 8
Hello.
E8 is a Paper Jam error that could be caused by:
- paper crumpling during scan.
- paper is multi-feeding all at once instead of feeding separate.
- scanner continuously tries to feed after paper has fed through.
if the paper is crumpling during the scan, make sure the inside of the scanner is clear of any obstructions. use the paper guides in the ADF tray to keep the paper straight when feeding in.
if the paper is multifeeding while scanning, fan out the pages before inserting them into the scanner. if problem persists, try cleaning the rollers with rubbing alcohol and a lint free cloth.
if scanner tries to continually feed after the paper feeds through, the ADF tray will need to be reseated. open the scanner and remove the ADF tray at the top. line up the 4 keys at the bottom of the tray with the 4 corresponding key slots inside the scanner. push the tray back until it clicks into place.
We also have an extensive support site and knowledgebase at
http://www.xeroxscanners.com/en/en/support/
If you continue to experience trouble, please feel free to contact us by calling 800-648-0410.
Regards,
Jan 28, 2013 | Xerox DocuMate 162 Pass-Through Scanner
I need the drive gear for the adf on a xerox documate 636,its the only gear when you open the [email protected]
the only place you can buy this is from xerox direct. Please locate your nearest xerox dealer and obtain a part number from them:)
Dec 04, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
Where can I get ADF parts?
eBay: Find Xerox Documate 510 Workgroup Scanner w/ADF - PARTS UNIT in the Computers Networking , Scanners , Standard Flatbed Scanners ...
cgi.ebay.com/Xerox-Documate-510-Workgroup-Scanner-w%2FADF---PARTS-UNIT
Dec 03, 2009 | Canon imageCLASS D880 All-In-One Laser...
I have a xerox documate 510 scanner I can not scan more than one page at a time through the feeder
Clean the rubber rollers with Iso Propyl Alcohol. If worn out replace them. Fan the papers so that they are not sticky. This should work.
S. Mohan
Aug 27, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
No paper message for ADF
I called Xerox and the technician told me the ADF cable was loose. I went home readjusted the ADF cable and now it works like a champ.
Jan 19, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
Documate 510 Roller Pad Assembly
Hi, I don't know if it's permissible to advertise but we currently sell the assembly for the Xerox Documate scanners. As far as I know the scanner's discontinued, and the pads are getting pricey so consider how much longer you want to wait before replacing the scanner.
sales at sprucecomputer dot co dot uk if anyone is desperate
Sep 21, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Documate 510 scanner ADF problem
Hello.
If the feed rollers are worn out beyond the point of cleaning, you will need to have the scanner serviced or replaced.
Regards,
Dec 07, 2007 | Xerox DOCUMATE 510 Flatbed Scanner
Document not moving all the way thru ADF.
The roller and retard pad need replaced. They are simply worn.
Oct 19, 2007 | Xerox DOCUMATE 510 Flatbed Scanner
Xerox DOCUMATE 510 Flatbed Scanner Logo
320 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
