Microsoft Xbox 360 Controller Logo
Question about Microsoft Xbox 360 Controller
Xbox 360 no lights? - Microsoft Xbox 360 Controller
1helpful
Hello my problem is in xbox 360 elite e 73 one light red
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Xbox-360 elite lower right hand red flashing led light code error E73
Xbox 360 one red light bottom right
1helpful
One red light on xbox 360
In most cases If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages.
HERE IS THE RED LIGHT REPAIR MANUAL: http://docs.google.com/viewer?url=http%3A%2F%2Fpdftown.com%2Fpdf-ebook%2FXBOX%2520360%2520Repair.pdf
4helpful
3answers
Xbox 360 won't turn on
I had this problem. Make sure the pins in the USB ports (2 on the front and 1 on the back of the console) aren't bent and there's nothing obstructing them. I unbent some of the metal inside these ports, and voila! I have a working xbox.
2 red lights
Your xbox is overheating.
1. Let your Xbox 360 console cool. You may have to wait several hours for your console to cool enough. Don't turn on your Xbox 360 console when the console is hot. 2. Verify that your Xbox 360 console has enough ventilation and that the fans are operating. 3. If the two lights continue to flash after trying the above steps, you'll need to contact Xbox Customer Support.
16helpful
2answers
Power brick colour
Alright, lets fix this!
 Xbox 360 power supply light is orange or yellow.
Usually when the Xbox 360 power supply light is orange it's on standby so there is no problem with your Xbox 360 console but the power supply can't supply it with power !
First you have to try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for a minute then reconnect it all back , also try it on another wall outlet without any extension cords at all.
If it's still doing the same it will be definitely a fault with the Xbox 360 power supply.
So, in this case please contact Xbox 360 customer support to fulfill the Xbox 360 power supply.
Xbox 360 power supply light is red.
There is something wrong with the Xbox 360 power supply connection so try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for minute then reconnect it all back , also try it on another wall outlet without any extension cord at all.
If it's still red that would be for sure a fault with the Xbox 360 power supply .
So, then contact Xbox 360 customer support to fulfill your Xbox 360 power supply .
You can also find replacement power cords many places online. See if you can get your hands on another cord and try that to see if its the current power cord.
Hope this helps you out! Please don't forget to rate :)
Xbox 360 repair in mumbai :- 9819767710/9867635653 ?
HELLO ALL GOOD NEWS FRIST TIME IN INDIA
XBOX 360 3 RED LIGHT ? NO PROBLE CALL ME NOW
WE ARE PROFESSIONAL ALL TYPE OF VIDEO GAMES REPAIRING. NOW WE HAVE NEW SOLUTION FOR XBOX 360 3 RED LIGHT FIX. WE CAN FIX 3 RED LIGHT PROBLEM WITH GUARANTIED.
NOW WE CAN PROMISS U FOR YOUR XBOX 360 VERY EASY NEVER BECOME 3 RED LIGHT PROBLEM. NOW WE HAVE VERY GOOD SOLUTION FOR 3 RED LIGHT.
IF YOU WANT BEST SERVICE AND SPECIALIST REPAIRER FOR YOUR ALL TYPE OF VIDEO GAMES.
PLS FEEL FREE CONTACT US
MAHBOOB ALAM & SERAJ AHMAD
MOB : +919867244969
EMAIL : [email protected]
Website : http://sonyservice.en.china.cn/
2 red lights
This problem may occur when the Xbox console is too hot or is overheating. The flashing lights mean that the internal temperature of your Xbox 360 console has exceeded acceptable temperature limits. Let your Xbox 360 console cool. You may have to wait several hours for your Xbox 360 console to cool enough. Don't turn on your Xbox 360 console when the console is hot.Verify that your Xbox 360 console has enough ventilation and that the fans are operating. If the two lights continue to flash red after you try steps 1 and 2, contact Xbox Customer Support.
Microsoft can be contacted by finding the number listed on the back of your video game booklets.
Good Luck to you and Happy Gaming.
Source:
http://support.microsoft.com/kb/907533
3 light
You can easily fix your XBOX 360 - With The Official XBox 360 Repair Guide from www.3RedLightFix.com
Fix your XBOX 360 in less than 1 hour with an XBOX 360 Repair guide from www.3RedLightFix.com.
Top Microsoft Video Game Consoles & Games Experts
David Shaub
Narseman
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
