SOURCE: connecting asus notebook via hdmi to LG 42 plasma tv
best option to use s-video lead ...use fn + f-key that has little square printed on it ...hp mostly fn+f4
SOURCE: No audio from HDMI on HP Pavillion DV9700
If you are not getting any audio through the laptop without the hdmi cable check that the volume control has not been turned down on either the laptop or on the windows volume control icon in the bottom right corner of your screen. Sometimes the easy solutions are the hardest to find.
SOURCE: Use TV as external monitor from laptop
no tube tv won't mirror monitor. needs vga connection at the back of tv.go to store have a look at lcd or plasma screen.the card is ok.
SOURCE: Hdmi Port .
If the laptop has no HDMI port, the forget the whole HDMI thing cause getting it through that port when the laptop or desktop is not made for it will end up costing as much as a new computer altogether. You need to find out if the laptop has any Composite or Component outputs. Those are relatively easy to spot. a Composite output is usually a RCA jack and also usually colored yellow, and goes into the yellow RCA port on your TV next to the red and white RCA ports which are the left and right sound channels. The Component outputs are also RCA jacks, but are usually red green and blue cause each wire sends its own color to make up the TV's image. They will also go on the back of your TV near all the other RCA ports. Wether your TV has just HDMI and no other porte or not, or if it has either Composite or Component inputs or both, that i don't know cause i don't know what your TV is. As for the sound, if you also want it on the TV, you just need to go to the local electronics store and buy an adapter/wire that goes from a 1/8 stereo headphone jack to 2 RCA jacks on the other side, one being white and the other being red. See where i'm going with that?:P Plug the 2 RCA jacks from the wire you bought into the TV in the corresponding inputs that go with the input you plugged the image in, and the 1/8 stereo jack into the headphone output of your laptop.
SOURCE: Conexant HD Audio no longer working with HDMI to TV
yes they did not load all the patches and drivers for hd audio. they are stupid or lazy. you need the patch from microsoft
