Question about Mitsubishi WT-46809 46" Rear Projection Television
SOURCE: MItsubishi WT 46809- not staying on when turned on
One or more fuse devices open==caused by convergence IC shorted. Solution==replace fuse(s) and STK I.C.(s).
Posted on Oct 11, 2007
SOURCE: mitsubishi wt-46809 wont turn on
it will need to be checked by a tech to determine the exact cause
electech
Posted on Oct 31, 2008
SOURCE: power on 2 sec. then off won't turn mitsubishi wt-42313
with this model there may be a liquid spill on the signal board this is because one of the tubes is leaking
Posted on Jun 17, 2009
SOURCE: TV wont stay on
shutting down can be due to a blown fuse usually in the convergence section. the fuses are soldered in, with a voltmeter you can measure the fuses. if one is open then probably your convergence ICs are bad. about $250-$400 to have a field tech come to you and replace them. The other possiblity is a CRT (picture tube) fluid leak. this is more costly to fix, to check for a fluid leak pull the front lower panel and check for fluid on the chassis with a flashlight. I have sucessfully cleaning fluid from the chassis with electrical cleaner spray. after covering the chassis with a piece of plastic the set worked fine. A slow drip leak won't hurt the plastic, big leaks are another story.
hope this helps
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Aug 23, 2009
Testimonial: "Thanks, your detailed response answered all of my questions as to the possible cause, expected cost and suggested course of action. I appreciate it."
SOURCE: There is a green glow around everything in the
I am going to post some photos here for you. If you went into the customer menu and tried to adjust convergence and red and blue would move but green is skewed--you have a convergence problem.
Look at the photos and tell me if any look ANYTHING like your trouble. If you have a convergence problem with this model I HAVE START TO FINISH, STEP BY STEP INSTRUCTIONS I CAN GIVE YOU.
If this helped you rate this solution as I do this here for free.
SD TECH
Photos: OR?
Posted on Dec 20, 2009
Testimonial: "Thank you very much. Its somewhat like that but there isn't any ghost image, its more of a green outline around the images.there is alot of red in pic"
