Computers & Internet Logo
A
Anonymous Posted on Jul 13, 2014
Countif formulas I am trying to count letters in designated time frames. This time frame has 5 letter codes in it. Why does this formula give me a date instead of a count? =COUNTIF(B5:B33,"F")+COUNTIF(B5:B33,"C")+COUNTIF(B5:B33,"A")+COUNTIF(B5:B33,"B")+COUNTIF(B5:B33,"D") gives me 1/5/1904
Summer Kerekes
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jul 17, 2014
Summer Kerekes
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
695
Points
Are you trying to find how many don't have a letter? If so you might try "COUNTA" instead of "COUNTIF". You could also try looking at the format of the cell your formula is in and change it to general or number.
2 Related Answers
Anonymous
  • 28 Answers
  • Posted on Feb 17, 2008
SOURCE: formula
What kind of function are you asking for and what software are you using?
rmeyer
Richard Meyer
  • 80 Answers
  • Posted on Nov 28, 2008
SOURCE: FORMULA TO COMPLETE A COUNT TO A PERCENTAGE
I am not sure but I was looking at this problem and I thought the equation should be reversed as I put it below. This gives a percetage of the entrys that are of the value 1 as it seems you are looking for.
=COUNTIF(A3:A74,"1")/COUNT(A3:A74)*100
1helpful
Countifs formula
COUNTIF(range,criteria)
Counts the number of cells within a range that meet the given condition.
This COUNTIF formula appears to count only the Employees that have the value "F" in the designated container. ie. Female.
tip
HOW TO COUNT THE OCCURRENCES OF A TEXT STRING
In the cell that you want the result to appear in, enter the appropriate formula from the following examples.
How to Count the Occurrences of a Number
Use this formula
=SUM(IF(range=number,1,0))
where range is the range that you want to search, and number is the number that you want to count.
NOTE: This formula must be entered as an array formula. To enter an array formula, press CTRL+SHIFT+ENTER.
How to Count the Occurrences of a Text String
Method 1
Use this formula
=SUM(IF(range="text",1,0))
where range is the range that you want to search, and text is the text that you want to find (the text must be enclosed in quotation marks).
NOTE: The above formula must be entered as an array formula. To enter an array formula, press CTRL+SHIFT+ENTER.
Method 2
Use the COUNTIF() function to count the occurrences of a text string. For example, use the formula
=COUNTIF(range,"text")
where range is the range of cells that you are evaluating, and text is the text string that you want to count instances of (note that text must be enclosed in quotation marks).
Wildcard characters can be used within the COUNTIF function.
The asterisk character (*) represents more than one character. For example, to count all the cells in the range a1:a10 that contain an "x," you can use the following formula:
=COUNTIF(a1:a10,"*x*")
The question mark character (?) can also be used to represent one wildcard character -- for example, to count all cells in the range whose second character is the letter, such as "ax" or "bx."
=COUNTIF(a1:a10,"?x*")
1helpful
2answers
Hi, how do I find the 1st 2 letters in a cell and reference it to another. ie A1: 0209JJP001. I thus want to find "02" which is Feb (this would be a vlookup I assume). Therefore the 1st 2 letters...
To reference the first letters in a cell, use the left function. The syntax is =left(cell,#). So, to return the left two letters from cell A1, you use =left(a1,2). You can put that in a cell or incorporate it into some functions.
Excel formula
Use the COUNTIF command. The COUNTIF command can count the criteria for a range of cells. Since you can only use it for one range of cells or criteria, you simply add another criteria to the formula as follows: =COUNTIF(AG1:AG5,"X")+COUNTIF(Sheet2!L1:L6,"X")
Countifs
The formula in both versions is the same:
=countif(range,value)
i.e. The below formula will increase its count by one if any of the 18 cells it's checking are equal to 1.
=countif(A1:B9,1)
2answers
Apply the following:
COUNT(A3:A74)/COUNTIF(A3:A74,"1")*100 in order to obtain the percentage.
Microsoft excel Formula
create a dummy column (columnC) containing columnA&columnB
use countif at columnD to count the number of observations per combination of columnA and columnB (in particular those with blank entries in columnB).
2answers
Display calculation result in a previous cell
Look into the =SUMIF function, it sounds like this may be what you are looking for.
Hope this helps!
Excel problem
Have you tried countif?
= countif(c:c, "Yes")
The "Yes" is CASE SENSITIVE!
You may also have to do a combo:
= count(b:b) - countif(c:c "<>'Yes'")
Wher the 'Yes' is in single quotes and the entire condition is in double quotes.
2answers
Formulas
You may want COUNTIF if you're specifying criteria. For instance, if my prices are found in b3 to b7, here's a formula that will find all those that are less than 6 ($6.00):
=COUNTIF(B3:B7, "<6")
If you're using multiple criteria, such as you want to find all the prices that are greater than $5 and less than $8, the following will accomplish it. (The ABS gives you the absolute value of the result, in case the smaller number is first.)
=ABS(SUM(COUNTIF(B3:B7, ">5") - COUNTIF(B3:B7, "<8")))
Grand Canyon Tech
Grand Canyon Tech
