Question about FUJIFILM Cameras
What does a red camera icon mean?
AX550
shawn zhuang
  • 28 Answers
That means camera is set to "Auto" shooting mode.
Posted on Jul 31, 2014
How do I remove video icon
That means the camera is recording normally. Stop recording by pressing the record button. If that doesn't fix it for you, try resetting the camera to factory default options.
Sep 26, 2014 | Nikon COOLPIX P520 Digital Camera Black...
How to put date & time stamp on photos ax550
The date and time (and a lot more) are stored with each picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Sep 03, 2014 | Fujifilm FinePix AX550 Digital Camera
Fujifilm ax550 driver downlod
Do you really need a driver?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Jan 26, 2014 | Fujifilm FinePix AX550 Digital Camera
Ax550 won't take picture, shooting mode icon outlined in red.
you can try to format the memory card and then reinsert it to your camera again to try.
Check whether your camera is focusing or not. unless it focuses and its locked , the shutter wont get released.
it can be due to improper light or distance of the object, or even problem with your camera internally.
check if there is any noise while focusing,a jam can also cause such a result for some cameras.
Feb 04, 2013 | Fujifilm FinePix AX550 Digital Camera
Set date and time on fujifilm ax550
Press the MENU/OK button, press cursor-left, use cursor-up/down to select the wrench icon, press cursor-right, then select the "Date/Time" command.
If you need a manual, you may download a copy here. The setup menu instructions are on page 65, the date/time setting instructions are on page 13.
Nov 25, 2012 | Fujifilm FinePix AX550 Digital Camera
Icons and what do they mean
Speed cameras usually are located either at intersections or along roadways. Many red light camera models used at traffic intersections also function as speed cameras. These speed cameras will mail you a speeding citation if the camera thinks that you are speeding. Your GPS navigator is warning you about nearby speed cameras. It displays red as you approach the speed camera location where you could get an automatic electronic ticket if you are speeding.
Mar 08, 2009 | EarlyWarning Vehicle Parts & Accessories
Red flashing icon
Mine had that too. It means the backup battery is low. It's located in a panel behind the LCD screen. You can find details on page 19 of the users manual. If you don't have your manual, you can download it for free from canon's website.
Nov 13, 2007 | Canon ZR90 Mini DV Digital Camcorder
Flashing red icon
It must be the internal battery problem. Change the button cell that is located near the charging input jack.
Oct 03, 2007 | Canon Elura 100 Mini DV Digital Camcorder
Cameras Logo
19 people viewed this question
Top FUJIFILM Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Falling star
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
