I lost my ignition key. I want to switch out the tumbler in the ignition lock without taking of steering wheel. I don't need to replace the whole lock, just the tumbler. Thanks
Unfortunately without the key you cannot replace the tumbler without drilling. this damages the whole assemblywhich means that you do you have to replace the ignition key cylinder the procedure is to drill into the ignition key hole about an inch and a half with a 5/8 drill bit . make sure you drillr straight hole in the path of the key.after you drill the holethe whole cylinder will rotate and come outallowing you to replace it not sure if you can buy tumblers by themselves comes with the whole ignition cylinder with the tumblers inside of it
