Canon PIXMA MP830 All-In-One InkJet Printer Logo
Question about Canon PIXMA MP830 All-In-One InkJet Printer
What does Error Code NG #018?
What does this mean on the activity report?
Fax confirmation
most printer in the market has the same standard setting for the fax.
u can set the report many types for many user's purposes, some people want to save paper, save ink/toner, so they dont need report if the fax is sent but only print report if the fax is not good(NG or not sent)
it can be set to:
report off--means report will be print out only if the fax is NG
report off+image--means report will be print out if the fax is NG + the image of the page that is not sent(so we know which page is not sent through the image)
report on+image-- every fax activities( sent or not sent) will be reported, which is not recommended
etc....
how to set is depends on your printer, just go to the menu "FAX" and look inside the menu.
2helpful
Unable to send faxes Error code NG #018 appears
You need to apply Canon's firware update at http://www.canon.com and search for fumx310swin1040en.exe if you have Windows or for an iMac the file is MX310 series Firmware Upgrade Utility Ver. 1.040 (Mac OS X) with a file name of fumx310sosx1040en.dmg
1helpful
2answers
Every fax we try to send it comes up with a error tx report of "NG". What does "NG" mean and how can we fix it?
Hello.
NG means: Some or no pages sent.
Check the paper feeder to see if the page is pulling through.
Listen to see if the fax line "sounds"like it is working or if you hear dialing or not.
Hope this helps.
Please help - faxes not going through. "function not completed" NG #018 is this an error code?
is it doing it on all out going faxes or just a few ? #018 means the other side was busy or out of paper or not in service.
2helpful
Print activity report on my canon pixma mp830 and the result is NG.. trying to find what that means
NG only means the result is No Good. After the ng there should be an error number that tells what the problem is.
10helpful
2answers
Getting Error TX Report: Result 'NG' - what does this mean???
It means No Good or Not Good, fax was never received for a number of reasons.
2helpful
Canon pixma mp 830 on my fax activity report I
Yes,it means the fax did not go through,it will show OK on the report if it was succesfull
Need list of Fax result codes for Canon MF5550
NG 070 = Issue: ERROR LCD: CLEAR ADF, DOCUMENT TOO LONG
Solution: Reduce the length of the document
Reduce the length of the document to within 14" (356 mm).
Activity Report Codes
NG means "no good". it means your fax didn't go through correctly or wasn't received correctly. ie wrong number of pages etc.
Clive
Clive
old marine
old marine
