Question about La Crosse Radio Controlled Atomic Clock
How do I Now use my as seen on TV Jupiter Jack
Our local radio stations change from previous dial settings. Is there any way to use Jupiter Jack now??? My receipt is from October 22, 2009, and it worked great for my audio books loaded to iPod and was attempting same thing with iPad the other day with no luck
Posted by Julie Miller on
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
Can i download my fm local radio station
Buy a portable FM radio that has an earphone jack and connect it to your sound card on your PC. Then go download AUDACITY. It is a free audio editor recorder.
Mar 24, 2013 | Prolink PV-BT878P+ w/FM RC
How do i set the radio stations on my jvc kd-s26 radio
1. Tune to the station you want to set the preset to.
2. Short-press the "menu" button.
3. Using dial, select the preset you want to set it to.
4. Long-press the dial to store the preset.
Jul 16, 2012 | JVC KD-S26
How do I get Jupiter Jack to work with my BlackBerry 330?
as the ad states you need to place the phone in the holster that insert the jack in the headset plug then place your car radio on the station as stated in the manual and you are good to go
Dec 05, 2009 | AT&T Blackberry Curve 8300 Smartphone
How to hookup kindle to car audio system
This could be either very easy or a huge headache.
Easy way - The newer cars have an audio input jack, basically a headphone jack (1/8"). There are cables that you can use with 2 male connectors; one on each end. Set your car radio on AUX/LINE IN/MP3 and turn it up.
Hard way - Go to Radioshack or Best Buy, even Target or Wallmart, and buy an FM Transmitter. They shouldn't run over $20. You plug it into you cigarette outlet for power and/or takes 2 AA batteries. Plug the headphone jack into your Kindle and set the radio station on the transmitter to either a very low or very high radio station; somewhere where there is no station close by. Turn the car FM radio to the station you set it on and turn it up.
Sep 18, 2009 | Amazon Kindle 2
AT&T Spirit Phone
You’ll need either a 6-button or a 24-button set SPIRIT CS administration.
First the control unit ADMIN switch must be ON, the administration overlay must be in place on station 10, and the set must be plugged into control unit jack 10 (call processing is interrupted only at station 10).
After moving the admin switch, and before dialing Ftr 7 -
From station 10 press intercom, Press speaker, Dial *0, Dial 1, Then Press Ftr 7.
Each line indicator light will show the current dialing type for that line. If the light is OFF, that line is set for touch tone dialing. If the light is ON, the line is set for dial pulse
dialing.
To change the dialing type for a line or lines, press the line button(s) and dial the appropriate digit from the table below. You may press more than one line button to make the change on more than one line. If you enter a digit without first pressing a line button you will hear the error tone.
Be sure to turn the admin switch back off when you’re finished.
Aug 05, 2008 | AT&T Spirit 6-Button Stard Misty Phone
How to change set radio stations
How do you set the stations I don't have a manual on my Pioneer super Tracker 3-D
Oct 17, 2007 | Sony CDX-L400X CD Player
There was a power surge, and now my phone is stuck on pulse dialing, how do I get it back to tone? I can use the star key to bypass the pulse and put the phone on tone, but it only works one call at a...
Press speaker,
Dial *0,
Dial 1,
Then Press Ftr 7.
dialing.
Mar 07, 2007 | AT&T Spirit 6-Button Stard Misty Phone
La Crosse Radio Controlled Atomic Clock Logo
46 people viewed this question
Top La Crosse Home Experts
Lawrence Oravetz
Are you a La Crosse Home Expert? Answer questions, earn points and help others
