If its a 6 disk cd system the cd tray is wedge causing the cd option to not work. Most of the time one of the cd slipped out of its position causing it to wedge
On the radio, repeatedly press the Alarm Mode button until the desired alarm mode indicator below "Alarm" is displayed. The music note indicates radio and the sound waves indicate the alarm tone. If no icons appear on the display, that means the alarm is turned off
Radio and tone
Radio only
Tone only
Alarm off
To turn alarm 2 on/off, follow these steps:
Turn the system off
On the radio, press and hold the Alarm Set button. "Alarm" flashes on the display
While holding Alarm Set, press the Alarm Mode button once. "Alarm 2" flashes on the display
Release Alarm Set, and repeatedly press Alarm Mode until the desired alarm mode indicator above "Alarm 2" is displayed. If no icons appear on the display, that means the alarm is turned off. The "Alarm 2" indicator will continue to flash on the display for 10 seconds. When the flashing stops, alarm 2 is set
To set the Alarm 1 time - On the control panel, hold down ALARM SET and press TUNING up or down. The time display changes slowly at first, then more quickly. Release TUNING to stop. On the remote, press TIME. The ALARM indicator flashes. Press TUNING up or down. The time display changes slowly at first, then more quickly. Release TUNING to stop. Press TIME to return the display to the current time. To turn on the Alarm 1 function - Press ALARM MODE or ALARM in sequence to select the mode you want: tone, radio, both tone and radio, or off. For tone only, press until the indicator lights. For radio only, press until the indicator lights. For tone and radio, press until both indicators light. When the alarm goes off, the tone sounds. Press SLEEP/SNOOZE to turn the radio on. Press SLEEP/SNOOZE to pause the radio for 10 minutes. To turn off the Alarm 1 function - Press ALARM MODE or ALARM until the display shows no Alarm 1 mode indicators. To check the Alarm 1 setting - On the control panel, hold down ALARM SET to see the wakeup time. On the remote, press TIME to see the wakeup time. Press TIME again to return the display to current time. To wake to a preselected radio station with Alarm 1 - While holding ALARM SET, press the PRESET button for the station you want (change between AM and FM if needed).
To turn off, hold down the mode button until the alarm/radio symbols disappear. To turn off nap, hold down nap button. Is the alarm volume controlled by the radio volume?
use the selector switch on the top, switch it to wake 1 or wake 2. set the time that you want that alarm to go off. then push the switch all the way back to the left to deactivate it. then to activate the alarm, use the buttons on top labeled wake 1 or wake 2 to turn the desired alarm on. pushing that button repeatedly will cycle the alarm to either beep, radio, or it will turn that alarm off.
