Is the TV fixable or is it time to buy a new one?
SOURCE: Sony Trinitron KV-27S46
There is a problem in the sweep section of the set. The Horizontal sweep power supply most likly. there is nothing a layman can do as it will involve troubleshooting the solid state circuit. please find a trainded tech to assist you in this repair.
SOURCE: TV is out
I was advised the same - the power supply needs to be rebuilt - Sony parts only or else it doesn't last. Cost runs between $150 and $275 (Cdn)
SOURCE: Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Thanks,
Dan
SOURCE: Sony WEGA Fails to Turn On Stand-by Timer Flashes 7 Times
Follow the instructions from the image provide and see if that works, if it does not work; you have a hardware failure in your TV. The hardware failure could be the HOT or flyback transformer.
Let me know if you need further assistance.
SOURCE: Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
