SOURCE: my casablanca fan versa touch 2 does not respond to remote control -
I believe there is a dipswitch, and a non- dipswitch version. To sinc the remote to receiver, shut power off to the fan receiver by either a switch or breaker for about 10 minutes, turn power back on and press Hi, Medium, Low on the remote in that order. this should get them "talking" again. If this does not work, contact toll-free Jason at Fan Man Lighting 1-866-600-3267, he has 30 years experience with casablanca
SOURCE: fan won't go on
Possibly a bad receiver, contact Fan Man Lighting at 1-866-600-3267 and ask for Jason, he has 21 years experience with Casablanca
SOURCE: Casablanca Fan/Light Remote (Versa Touch #W-42)
This fan uses an RF /radio remote. To pick up the signals from the remote it must have an external antenna attached to the internal receiver - it's just a piece of wire. In your case this wire has been yanked out. You will have to open the fan, access the control box and see if the wire is still attached and in one piece - if not you will have to solder a new one in its place, a simple 10 minute job.
If you think that is too complicated then all you can do is to replace the entire control board. From here you can get the wiring, at the end.
http://www.casablancafanrepair.com/HTMLFiles/do_it_yourself/VersaTouchCommonRep/W42-43Wallcontrols/VToneOperation.pdf
If you wish to get setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
