Question about Stihl Ts400 Cut Off Saw Carb Carburetor Air Filter
Fuel is running through carb flooding out when pulling to start
Salvagedrover
    Sergeant:
  • Stihl Expert
  • 417 Answers
Nobody rebuilds a carburetor, it takes too long, is unreliable, and you're putting new parts in an old, worn out body, just replace the carb at that point. But I don't think it's the carburetor' fault. It's a cut-off saw that ingests a lot of stone and concrete powder so when the engine is sucking in air and fuel, it may also be sucking in extremely abrasive minerals that are wearing down the intake side of the piston. I would either shine a light through or completely remove the carb, and look inside the engine at the piston while you move the flywheel back and forth by hand. Is it super worn inside? Do the rings move up and down a lot in the piston grooves? You may need a new top end kit to rejuvenate your saw. Hope this helps.
Posted on May 03, 2016
  • Martin Purdey
    Martin Purdey Jul 07, 2018
    My stihl ts400 leaks petrol in air filter tried new carbs new tank vent pipe but still does it anyone no why
Tim Hofstetter
    Genius:
  • 1,406 Answers
The float valve is stuck open. It's time to rebuild the carburetor.
Posted on Jul 30, 2014
Trys to flood on cold start
what vechicle type model and the year.older cars carb type if automatic choke not working or vacuum pull off not working carb will flood out engine.for cold start up engine need good spark and fuel.if engine flooding could have weak spark due to worn out spark plugs and wires.could have vacuum leak or bad engine coolant temperature sensor.dirty air filter.dirty fuel injectors.
Dec 20, 2012 | Cars & Trucks
Yardman blower jut quit running like it was out of gas, restarted then did the same thing, now its difficult to pull the cord to strt
I'll guess and say that the carb flooded the engine and you have hydro lock.Pull the sparkie and clear the extra fuel.
The carb is at fault,IMO.
if the needle get a little dirt in there it will hold the float open and flood the motor.
Dirt.
Nov 16, 2012 | Yard Man Mulchinator QuickShift BlowerVac...
I replaced fuel line from carb to intake and now it wont start?
Check the carb fuel stub to see if its seated in the hose. Chech to see if you re-installed the piston underside scavenge hose to the bottom stub of the carb. Check your compression. New is 160 psi, operational but problematic (hard start) 130~140 and completely toast at 90. This saw is easy to flood when compression has fallen off. Cold start, 3 pulls choke on with the throttle trigger locked wide open. At first sputter, put choke in normal run and it should fire by the 3rd pull. If not its flooded. Then remove the plug and with an air hose vacate the cylinder of fuel for a few minutes and try again without the choke or throttle lock set at wide open.
Good luck.
Nov 27, 2010 | Makita DPC7311 73cc 14Inch Gas Powered...
I have a Toro 1984-85 self propelled pull start lawn mower and I can get the fuel and air mixture just right it won?t stay started, it runs great but gets flooded now (I think), does anyone have the fix-it...
If the mower floods, it may be a float problem, if you have a carb with a float. New fuels can destroy older floats, dirt and gum can keep them from closing off the fuel supply. If you are comfortable taking your carb apart I would start there.
You will need the engine make and ID to get a manual.
Jun 03, 2010 | Toro Lawn Mower With Toro Power Tools
Filling carb up with fuel
this sounds likke the float is sticking
Sep 08, 2009 | Saws
Mariner 25 hp 2 stroke hard to start then quits and won't restart
It sounds like the float is sticking in the carb. Since the carb is higher than the fuel tank it pulls the fuel in by vaccum of the engine. when running at high rpms, it can burn the fuel thats flowing into the carb, when you idle down, the bowl of the carb is filling up with fuel faster than the engine can burn it and causing it to flood. Then when it shuts off at idle it does not want to start back up because it is flooded. To make a long stary short, pull the carb and give it a good cleaning and your problems should be solved.
Aug 01, 2009 | Light Outboard Motor Boat Bass Fishing...
The engine on my Sprint 375 floods when trying to start
Check the float in the carb. bowl for gumming and clean your carb.. If you haven't done so already. Or you can try running a fuel treatment through your fuel. That may help you with your flooding issues. Good luck.
May 04, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Dirt bike thats hard to start..
needle and seat are worn out in carb, to much fuel is flooding cylinder. remove carb, clean, get new needle and seat, set float. problem goes away. pull your plug after kicking. its probably wet.
When you push, or pull start you evacuate excessive fuel, when engine is warm, easier to start extra fuel burns easier.
Mar 15, 2009 | Yamaha YZ 250 Motorcycles
When start bike up,it runs on 4 then onto 3 then 2 then cuts out.have stripped carbs rebuilt,balanced them.new plugs.runs fine till warm,think may be fuel problem. changed fuel tap.ballenced carbs with 2...
Are the cabies flooding or runing out of fuel? pull the choke on dose it help if it does low fuel.
Drain the bowls and see if there is plenty of fuel.....If its flooding turn the fuel off or block it when the engine starts to drop clys if it starts to pick up after 10secs or so the carbies are flooding
Feb 23, 2009 | 1988 Suzuki GSX-R 750 J
Stihl Ts400 Cut Off Saw Carb Carburetor Air Filter Logo
Top Stihl Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Stihl Saw Expert? Answer questions, earn points and help others
