Question about Hunter Fan Company 5/1/1 Programmable Thermostat
My thermostat is flashing a 4
What does it mean when my thermostat is flashing a 4
Air conditioning not working. Have White-Rodgers thermostat 1F79111, I think. Replaced batteries. Now have flashing signal like an asterisk. What does it mean?
Blinking snowflake means it's on time delay for cooling to come on (usually 5 minute time delay to prevent compressor short cycling). Solid snowflake means cooling is on
Aug 03, 2016 | White-Rodgers (Protech) White Rodgers...
The unit keeps flashing
By unit, do you mean the thermostat? And if so, do you mean the whole face is flashing, or just a heat or cool symbol? And if your talking about the heating/cooling unit, are you talking about a flash on the board?
A thermostat face that is flashing is usually batteries.
A symbol that is flashing on a thermostat indicates a call and is in a delay. There will be a 5 minute delay on calls if the call has been short cycled, powered off and on, etc.
If the symbol continues to flash for an extended amount of time, then the problem is in the furnace, air handler, etc.
If the system is working, but flashing, then it could be the programming of the thermostat.
Dec 02, 2013 | Honeywell Heating & Cooling
Replaced amp now the honeywell just flashes and the boiler is switched off
If the power to the boiler is off, and you have a power stealing thermostat (tstat with a common), there may be battery backup. In which case, the thermostat is flashing because it is on battery backup. Not sure what you mean by replaced amp now.
Dec 02, 2013 | Honeywell Programmable Thermostat Heater
Turn thermostat up ignitor comes on but there is no gas flow to ignite. 4 flashing lights.
is the gas valve on? gas line cutoff set to allow gas to flow through. there should be a list on the control panel to tell you what 4 flashes means its probably no flame sensed. the board may not be sending power to the gas valve or the gas valve could be stuck.
Oct 11, 2013 | Heating & Cooling
Flashing 4
Reprogram it and then hold down the button that says hold until it goes back to the screen that should fix it the blinking 4 is just saying you are in the 4th programming stage of the day. Mine was blinking on 3 yesterday and when I reprogrammed it it stopped blinking
Jul 03, 2012 | Hunter Fan Company 5/1/1 Programmable...
I have a goodman furnace GMP100-4 REV B..about a year ago it was not working. The fan would start but it would not ignite. We found out we need a new ignitor and it was a good quick easy fix. Now a ye
Any light flashin on the control board? If not then look for a small fuse blown on the board. See lights a flashing count them flashes
A sampling of various failure codes on a furnace:
Read one LED flash that stays on continuously to mean your furnace has no signal coming from the thermostat and will not operate. Turn the power off and check the thermostat for improper settings or connections.
Interpret one LED flash that blinks on and off to mean your furnace has locked out because it could not ignite after three tries, and must be reset. Interrupt power to your furnace for 20 seconds or lower the thermostat so your furnace does not try to heat, then reset the thermostat to the previous setting. After one hour of lockout, your furnace will automatically reset itself and try to operate as usual.
Decipher two LED flashes to mean the draft blower is not working, or your furnace has a short in the pressure switch circuit. Turn off the furnace power and repair a short or replace the pressure switch.
Read three LED flashes to mean your furnace has an open pressure switch circuit or it has an induced draft blower operating. Check the pressure switch hose of your furnace for blocks or an improper connection. Also, look for blockages in the flue, and tighten any loose wiring.
Translate four LED flashes to mean your furnace has a primary limit circuit open, possibly from loose wiring or blocked filters. Check and clean filters, tighten wiring and check the flue for blockages.
Interpret five LED flashes to mean your furnace senses a flame without a call for heat. This could be from a gas valve closing slowly or a burner flame lingering.
Read seven LED flashes as a warning of a low flame sense microamp signal. This could happen with a coated flame sensor or a lazy flame from poor gas pressure. Turn off the power and adjust the gas pressure according to the information on the rating plate.
See eight LED flashes as meaning an igniter circuit problem due to a bad igniter or an igniter connected improperly. Replace the bad igniter or check the ground wiring, making necessary corrections.
Decipher nine LED flashes to mean the high-stage pressure switch circuit will not close during a high-stage-induced draft blower operation. Your furnace may have a pinched or blocked pressure switch hose, a blocked flue or loose wiring.
Read continuous flashing on the LED to mean your furnace has a reversed polarity of 115 volts. Turn off the power and correct the wiring polarity after reviewing the wiring diagram.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 29, 2011 | Goodman Heating & Cooling
The thermostat is flashing and E2 error code...what does that mean
It means the trailer is too warm for the thermostat to work - above 90 degrees inside. Take some ice and put in ziplock bag - place over thermostat and cool it down. Unit will start working when thermostat senses it is BELOW 90 degrees. FAULTY DESIGN.
Jul 06, 2011 | Dometic Rooftop RV Air Conditioner
My central heating is on lockout and the burner is with red light
A sampling of various codes on a furnace
Interpret five LED flashes to mean your Goodman furnace senses a flame without a call for heat. This could be from a gas valve closing slowly or a burner flame lingering.
Dec 02, 2010 | Heating & Cooling
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
1,583 people viewed this question
Top Hunter Dryers Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
