Question about Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore quietguard 3 has flashing orange light on normal wash and wont start
Will not reset or start...flashing orange on normal wash
5 Related Answers
David Coomer
  • 1073 Answers
SOURCE: Kenmore Quietguard 2
check the water inlet valve first
Posted on May 05, 2008
Anonymous
  • 4 Answers
SOURCE: Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Posted on Jul 01, 2008
SOURCE: Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Hi Claire,
Are you using rinse aid?
that may help with the film.you may also have stuff down in the trap causing the water to drain slow.
Posted on Nov 05, 2008
Anonymous
  • 338 Answers
Not draining may either need new drain motor. or something is blocking the drain pipe.
Spots on dishes means you are using to much detergent or the wrong kind of detergent.
Your owners manuel should tell you what type to use.
Posted on Nov 25, 2008
Jrussell789
  • 172 Answers
SOURCE: KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Posted on Feb 22, 2009
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
Kenmore Ultra wash mod.# 665-77963K703. normal wash light flashing. How do I reset.
How many times does it blink before pausing and repeating? 7 times? (That's a common problem - means "water not heating" error.) In some dishwashers, instead of pressing Heated Dry, Normal Wash, Heated Dry, Normal wash, you press the 3 left-most keys in the following order: 1, 2, 3, 1, 2, 3, 1, 2, 3. That will start the diagnostic cycle and clear the error, but if you don't find and fix the cause, the problem will come back the next time you run the DW. But before I try to explain how to fix the root cause, I would need to know how many times the light is blinking.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jan 09, 2015 | Kenmore Dishwashers
My kenmore dishwasher will not start. Only the options buttons light up.
1) power home. c.breaker tripped reset or blown fuse
2) door switch, test for open or defective replace
3)wires for open, break or burn, repair
4)timer or selector swtich, test for open dirty contacts, loose wires, break or burn, or open switch replace.
God bless you
Jun 19, 2012 | Dishwashers
Kenmore Ultra Wash Model 665.1388 problem the normal wash green light is on heated dry light is on and the start resume light is flashing but wont startup helpppp
see your instruction manual and go to the section troubleshooting and fix it.
if you do not have the i.manual download for free www.retrevo.com or www.fitness.manualsonline.com
see the diagram
God bless you
Jun 18, 2012 | Kenmore Dishwashers
Kenmore quietguard standard wont start.
is there any function at all? if not, check thermal fuse located inside near control panel, check www.searspartsdirect.com and enter your model # to show how to take it apart. If it has functional display lights, replace main control board after ohm test on wash motor and fill valve.
Jun 25, 2009 | Dishwashers
Green light on kenmore dishwasher is flashing
I actually had to change the steps a little and this is what I did:
press heated dry
press normal wash
press heated dry again
press normal wash again
wait a few seconds
all the lights should come on
press cancel (should hear pump)
hit cancel again
Started a cycle and began washing.....Thx
Dec 31, 2008 | Kenmore 24 in. 16039 Built-in Dishwasher
Kenmore Dishwasher - Flashing Lights - wont start
Is the clean light blinking 7 times? If so this means you have a problem with your heating element
Dec 03, 2008 | Kenmore 15899 Built-in Dishwasher
Jun 08, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Zanussi zwf 1432 w washing machine
pcb as the signs were that the pcb was stuck in a programme and unable to change. Anyway, long story short, to fix it:
Take the lid off the washing machine (2 screws at the back) *unplug first
Locate the pcb, unscrew and lift above the washing machine with all wires in tact.
Locate the wires that are coming out of the back of the "program" board, it should be 2 blue wires.
Follow these back to the pcb and unplug
plug in washing machine
Turn on washing machine
Only the on/off light should come on
Whilst on, and being careful, plug back in the wires you unplugged
VOILA, fixed washing machine!!
Right, have to go, got a weeks worth of washing to do!!!!
Feb 24, 2008 | Zanussi ZWF1430W Front Load Washer
Kenmore 24 in. 15689 Built-in Dishwasher Logo
85 people viewed this question
Top Kenmore Dishwashers Experts
gbob59
Marvin
Marvin
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
