I have tried to adjust size. not able to fit words on side of TV screen. I am not sure as what to adjust when I am in asptic ratio. can you help? I select auto fit and still not getting picture. I also try my provider optimum's remeote to adjust.
SOURCE: picture cut off for my flat screen pansonic tv, zoom adjustment grayed out and i cannot adjust?
Without that model number (should be on receipt or owner manual for set) do not expect anything here other than a general answer.
If the zoom is grayed out it may be normal depending on what is connected and how. If you are using a box of some kind hooked via rear inputs the box may be the reason---it may control or cause this to be grayed out---a simple answer to a question: Do you have the same problem with a DVD etc hooked up to a rear input?
