HP Pavilion m8020n  PC Desktop Logo
A
Anonymous Posted on Jul 12, 2014
Code 31 can not connect to internet at computer get a code 31
Georgia B
Level 3:
Guru:
  • Master 1,342 Answers
  • Posted on Jul 15, 2014
Georgia B
Master
Level 3:
Guru:
Answers
1342
Questions
0
Helped
879218
Points
3834
Code 31 seems to be a driver issue. If you don't have a CD you can download the drivers for you PC from Dell using the link below. http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&product=3377259
2answers
Cannot connect to internet and Microsoft Virtual Wifi
Dexel Bruno,
To turn the wireless on you would press FN+F2 or F2. The link below refers to the MS Virtual wifi error 31.
http://bit.ly/1IXELU1
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Dell error code 31
Open Control Panel and then Device Manager (or System, then Device Manager).
Look for a yellow balloon, this should show you which device is giving the Code 31 error.
Then you need to fix the problem by re-loading the driver.
I can't connect to mifi, adapter #5 code 31
click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver if you see a yellow ? ! question or exclamation mark or red x means you need to install/update driver right click to install driver
the driver could be on the motherboard disk or the one supplied by your ISP internet service supplier or you might need to download it
hope this helps
Acer aspire 5515 wireless quit working says code 31 have tryed to reload the drivers still nothing
The best way to check if the computer can access to Internet is to boot the computer to "Safemode with Netwroking", to do so, restart the computer and as soon as it restarts keep on tapping F8 key, now select "Safemode with Networking" from the Advance boot menu. Try to connect to internet. If you are able to connect to Internet then the issue is with the firewall on you computer, contact the firewall manufacture or settings. If you are still unable to connect to Internet, then the internet setting are not correct, you may need to contact the ISP.
Thanks and regards,
Anil.B.R
1helpful
Hello, i have a hp notebook which code 31 error on
http://support.microsoft.com/kb/932520
Microsoft says to Ignore the problem, and the adapter will continue to work correctly. If the message is really annoying maybe you can try turning off IPv6.
Control Panel\Network and Internet\Network Connections
right click your network card>properties
uncheck the IPv6 box
that'll turn off IPv6-then just disable the adapter driver
2helpful
Toshiba satellite wont connect to internet. Wireless network adapter showing vista error code 31. Any ideas
Try removing the wireless adapter in the device manager and then re-boot computer. Vista should detect the adapter and re-install the drivers. if that does not work you might want to download the latest drivers and software from Toshiba and install them. Another thing you can try is to use windows restore to return the computer to a time when the wirless adapter was working.
Cannot connect to wireless
Hi, reinstall the latest adapter drives.
87 nissan quit code 24 and 31 shows - would it be the computer that needs to be replaced?
1987 nissan showed code 24 and 31
also made dashboard lights go haywire
PROBLEM solved by self -- DISTRIBUTOR
1helpful
Error code 31 4 to 6 network adapter
Check these things:
  1. Is you Ethernet adapter Active
  2. Is your Cable the correct one (NOT a cross over)
  3. Refresh your IP Address for your Ethernet Card
  4. Reboot your computer and power down your modem, then power the modem up AFTER your windows is logged on
  5. Verify your modem "really" can connect, use another computer.
  6. Verify the are no network issues with your ISP
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
