MSI K8MM-V Motherboard Logo
A
Anonymous Posted on Jul 12, 2014
Audio driver g31 series destop motherboard - MSI K8MM-V Motherboard
danijel_33
Level 2:
Habit-Forming:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 154 Answers
  • Posted on Aug 04, 2014
danijel_33
Expert
Level 2:
Habit-Forming:
Night Owl:
Answers
154
Questions
0
Helped
23572
Points
202
Http://www.msi.com/support/mb/K8MMV.html#down-driver&XP%2032
It's not g31 seris, it is AMD mbo. Pls download Via 4in1 driver for this mbo.
Please help me. I want to download Intel G31 audio driver.i can download g33 drivers and i was installing g31 audio driver, but did not work..
You can download the motherboarddrivers from Intel WEB site. Select your model
motherboard/device, and makesure you select the Windows XP or Vista version of the drivers that matchesyour Windows operating system. Please click on this link andselect your model motherboard : - http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
2helpful
CD of my asus mother board G31-M7 TE have been lost, Now my audio divice not working, request provide the driver for my instalation Thanks
The Biostar support website can be found here.
There you can download all the drivers for you motherboard including: Chipset, Onboard VGA, LAN, AUDIO and USB 2.0 drivers.
Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated.
Thanks.
1helpful
2answers
G31-M7 TE verson 6.4 audio problem. when computer s raning this time beging nosie sounds out . ple tell me how can solve this problem its urgent thanks
go to here http://exehub.com/biostar-g31d-m7-motherboard-drivers-specs/ and install the correct driver for your operating system http://exehub.com/biostar-g31d-m7-motherboard-drivers-specs/ and click 'best solution please.
I got problem to input sound on g31 motherboared, please guide me how can i input sound in g31 motherboard>
The G31-M7 TE MB has a intergrated sound chip.
Enter the bios. Open Chipset. Open South Bridge configuration. Find Audio controller. This should be set to [Azalia] Save and exit the bios.
Next check JAUDIOF1: found on page 14. If you are not going to use the cases front audio and mic than there should be a two pin jumper covering pins
5 & 6 and pins 9 & 10. If you're case supports front audio / mic ports, (You can not use the front audio ports and the rear audio ports at the same). time). Once everything above is set, got to Biostar and download the audio driver software;
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=363
If you still have a problem with you're sound. Explain any actions you have taken.
Mike
2answers
I am using g31 mb my front audio not working, but back audio working fine. i checked cable and everything but same problem.
Hi
Check your bios settings for any front panel port settings and make sure it is enable.
Also check for the audio jumper settings. Refer to the motherboard manual.
Hope it helps..Thanks for using Fixya.
1helpful
2answers
No sound on Biostar G31-M7 TE Motherboard
try getting a cd rom audio cable plug it in the back of the cd player and plug the other end into the motherboard
2helpful
Driver for ecs g31t-m series with 6 ports audio
you collect in intel g31 mother board driver from www.intel support.com
1helpful
3answers
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
