I have a vetch cs6649-2 corded/cordless phone set. I can make calls on the phone but cannot receive calls. How do I receive calls on this phone? I have a vetch cs6649-2 corded/cordless phone set and can make calls on the phone but cannot receive calls. How can this be corrected to receive calls?
SOURCE: vtech 9127, display bad
my vtech 5.8 GHz disconnects while I am talking~replaced batteries and charges the phones for 24 hours. I cold talk 10 minutes during this time 4x I could hear the other person~they could not hear me and then disconnect.
Characters and numbers are choppy too
Thank you
SOURCE: My vetech cordless phone is not working
DO you have a 2 line model? If so check and make sure the conf (conference) button is not pushed as it will keep the line off-hook forever. Hope this helps!
SOURCE: How do I do a 3-way call with Vtech cordless phone
WHAT TO DO FOR REMOVING MSDC SECTOR ERROR FROM MEMORI CARDS.
SOURCE: my vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
Does your handset have a PROG button? Press that, then press the VOL+ button until you come to RINGER VOL: OFF. Press SELECT button, then use the ^ (VOL+) key until you get the desired volume level. Press SELECT again, then OFF. You're good to go.
SOURCE: hi, how do you turn the ringer on of vtech 5.8 GHZ
http://www.retrevo.com/d/ds/progress?doc=415c14b0b538f65e013116610ddd5a8a
Click on the above for your manual and go to p7.
Hope it helps!
