Usually the condenser fan blade hitting on some part of the condenser or shroud.If you can access it, check the fan mountings, and blade for straightness.
To be honest it sounds to me like your fridge may be ok?
To extract the heat from within the fridge interior a compressor (motorised pump) moves gas around a series of pipes around the cabinets insides. This movement of gas causes heat to be picked up and taken away externally to the outside world. When the fridge temperature reaches a predetermined level (around 5C) the compressor shuts down and all is quite. The sound of running water you hear is the coolant gas changing state from gas to liquid and running through the coolant pipes. If the fridge is doing it's job and keeping the content cool then I wouldn't worry. One of the reasons you are probably noticing this sound is because it is a table top fridge. Built in fridges make the same noises but you don't really hear them so much because of the cupboards screening the sound.
His idea makes sense. If the noise stops sometimes, then pretty much that is it, especially if the noise is near the top of the freezer and not down below. Unfortunately some fans are hard to get to. Best of luck.
Hi Linda. We have the identical model of Woods all-fridge and experienced this problem several times over the course of several months. Hopefully this is still timely.
The short answer is that the clear flexible-plastic drain tube that runs from the inside rear of the fridge down to the catch tray (underneath the cabinet, next to the floor, behind the kick-plate) is sufficiently plugged (with some kind of gunk, probably from a spill inside the fridge) to cause a back-up. I suppose the inner diameter of the tube is maybe 3/16" so it can easily get clogged. Consequently, the water runs down the inside back of the fridge & eventually ends up in the depressions below the crispers. In our case, after those depressions filled (and I hadn\'t noticed), the water would run out onto the floor.
Initially, I used a fine wire to poke some of the gunk out of the tube but I didn\'t get it all out. Just enuff to let some of the water get thru, but the tube would plug up again. After a few repeats of the problem, separated by a month or 2 each time, I decided a more "drastic" tube cleaning was required.
I suppose a good strong compressed air blast might clear the tube completely, but I didn\'t have that available so I had to use a semi-flexible wire & sorta gunk out the tube. It\'s been about 1.5 yrs. since that more thorough tube cleaning & the problem hasn\'t come back, so I think the tube got plugged from a spill in the fridge (which thankfully hasn\'t re-occurred... yet).
BTW, I don\'t have the manual either, but the lower part of the tubing is accessible from behind the fridge. I didn\'t pull it completely out (which might have disconnected it from its fitting), I simply reamed it out while it was in-place.
There are only two other parts in the freezer that can make noisei if your icemaker is off. The evaporator fan motor makes noise when ice builds up around it, and the blades start hitting the ice. It also makes noise when the bearings start to fail on the motor. Rarely, the evaporator will make noise when the freon is pumped through it, we will get all kinds of strange noises. This is not a problem usually as long as your termperatures are fine. To check these items out, you will have to remove the icemaker and the back inside panel in the freezer. With it off, you can pinpoint where the noise is coming from. If it is a bad evaporator fan motor, replace it. Good Luck, Appliance Specialists
That's usually mounts inside thecompressor. It could still last awhile so if you can put up with thenoisejust wait for it to
quit before replacing thecompressoror getting a new
fridge.
hi
i had the same problem with mine,and fixed it very easily in about 10 minutes all you do is take all the shelves and draws out, then remove the light cover (one screw at the top)then the bulbs,there are three screws on this panel top middel and bottom,take these out,now gently pull the panel off,behind are two plugs unplug these and completly remove the panel.
next unscrew the water chiller at the bottom of the fridge and lay it in the botttom,take the deoderizer cartreges out and remove the two screws out from behind there,just two more screws at the bottom of the panel,there should be two plugs at the top of the panel,unplug these and remove the panel completley ,if like me you should find the fan all iced up, some warm water on a spunge should remove this and the fan should move freely if the ice is severe then remove the fan motor and run the panel under some hot water untill the ice is gone,assuming the motor is'nt burnt out this should cure it.if you want to test it plug the panel back in also the light panel ,and hold the light switch after about 30 seconds to a minute the fan should run,now just put it back together and thats it....
sounds like either your compressor is loose and just rattling or the compressor is off balance and its rolling around inside the seal can. take a look at it when it is making the noise. put your hand on the compressor (careful might be hot) if it feel like it running smoothly then i would call an electrician cause that kinda puts me out of ideas without being there... sorry
