AC not blowing cold enough. Complete AC system has been replaced compressor, evaporator, etc. Still not blowing cold enough. No change. Maybe vent issues? Need help...please
SOURCE: A.C. NOT BLOWING COLD
My AC went out suddenly and it turns out I got a major leak in one of the tubes in the AC system and thus warm air. When I bought the first can of refrigerant it didn't take much to get the pressure back where it should be. After some good advise I learned that my compressor was kicking on and off (you'll hear it cycle on and of every few seconds or so) and not STAYING on. Turns out because the system was drained of coolant I had to fill the tank a little at a time and actually go over the recommended pressure to force the air out of the line and get enough coolant in the system to kick the compressor on.
Turns out it was all for not...given the hole in my system it just leaked right out. I live in GA and still don't have it fixed; I was quoted $800 to fix it and figured I could live with it.
SOURCE: 02 town and country blows hot out of some vents
You probably have a 134A leak. My 2001 did same thing. Located a leak at bottom of condenser, replaced condenser, and it's fine.
SOURCE: 1997 Chrysler town and country
I found a sticker after looking under the hood with the AC information.
Thanks!
SOURCE: MY AC IS NOT BLOWING COLD
not happy here i bought a machine for recharging A/C and now they have started selling the gas in a can in the supermarkets ,2400€ for a machine and you can buy a can for about 25€ .could have a blocked restrictor valve ,venturi valve by whatever name you call it but its in the actual pipe on american cars and on the new ones here now as well,only need a bit of dirt to move in the system and it will block this valve evan if someone has put a leak sealer in this could cause the valve to clag up and not allow the gas through.strip and clean whole system blowing it out with an airline.This gas has to be recovered with a machine and released into the atmosphere.
