Question about HP Officejet 7210 All-In-One InkJet Printer
SOURCE: glass cleaning
first remove scanner cover look at how it is connected in hiddle is raised piece dont rember if you push towards front or back of printer its been awile scince iv had to do this one on left side of scanner is two screws screws on right are under control panel to remove this carefully take off cover over numbers by putting small screwdriver at bottem of lcd and lift up on cover over buttens after this is up find small slot on very front middle where this cover was if you press down carefully and slide control panel forword to release do slowly two ribben cables attach it remove carefully then remove all screws with T-10 driver glass and outer plastic should lift do not damage ribben cables after glass clean put cables back thru slot carefully replace screws reattach control panel cables look at how it slides back on
Posted on Mar 16, 2008
SOURCE: HP photosmart 2710 dirty glass
hi,
no way.... u cannot clean the underside of the glass... u can clean the glass using a lint free cloth....
thanks and regards
agnel
Posted on Mar 18, 2008
SOURCE: glass dirty on bottom side
Here's the HP link to clean most of the scanner printers
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00553775&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Posted on Apr 06, 2008
SOURCE: My HP3030 scanner glass is dusty on the underside
Yes you can. Just be careful not to force any movement of the scanner lamp. Be gentle. Otherwise you have nothing to fear.
Posted on May 04, 2009
SOURCE: How do I remove the glass plate to clean it?
On ones like your model, you lift the cover off of the keyboard assembly, and either remove tape covers over the screws or press a lever and slide the keyboard toward the front. After that unplug the ribbon cable and then there are torx screws all around holding the glass. They usually snap in the front and have screws to remove at the rear.Don't lose the tiny white rollers on the scan bar...
Posted on Dec 13, 2009
