Question about Vector Black And Decker High Frequency Automatic Battery Charger
My 98 blazer acts like the battery is dead but when i hooked it to a battery charger it said it was full and running at 9.1 when it should be running at around 12 then said error f03. so what does that mean and how do i fix the problemI?
Tim Hofstetter
    Genius:
  • 1,406 Answers
It means the battery charger is your problem. Find an old-style simple battery charger, not one of these new "smart" chargers. The simple ones allowed YOU to decide whether to charge or not. Placed more responsibility on you, but a simple charger would WORK for your battery.
At 9.1V, your battery's DEAD.
Posted on Jul 26, 2014
1 Related Answer
Charles Tidwell
  • 475 Answers
SOURCE: what does "sulfated Condition" mean
The battery is dry. It has insufficent acid in the battery
Posted on Feb 26, 2011
2002 Chevy Blazer. drove to the store and home okay, went back out to start it less than ten minutes later, won't start,
Check ground wires. Battery to engine, battery to body and engine to body. There are more. These are the main three.
Aug 13, 2015 | Cars & Trucks
98 honda crv wil start if jump started and then later won't start
Your battery is not fully charged and may not be accepting a full charge. Remove your battery and put it on a charger overnight. Take the battery to a parts store and have them hook it up. They will then be able to tell if it is taking a full charge or not. If this is a new battery it will take a full charge but it is still getting drained by something such as a radio not shutting off automatically, if you have that option.
Oct 07, 2012 | Honda Cars & Trucks
Battery seems dead
charger doesnt have a high enough amp out put to tun the vehicle electrical system
Jun 28, 2012 | 2003 Saab 9-3
Squeeze trigger once and it fires 3x
if there is a 9 volt battery in the handle, there should be 3 to 5 small dip switchesright by the battery, your set on 3 shot burst, unhook the gas, turn all switches off, and test it, there is also a full auto setting, try different combinations untill you get single shot
Sep 15, 2010 | Tippmann 98 Custom Act Paintball Gun
Car won't start. Acts like the battery is dead, however I can't jump start it.
Well if you cant jump start it thats a good sign that the battery is dead so replace it and you should be fine, and another way you can try is hook the battery up to a charger overnight and if it doesnt hold its charge then you will know if its dead or not.
Jul 04, 2009 | 1998 Oldsmobile Aurora
1996 Chevy Blazer battery draining/won't start
What normally you have to look for is that your belt is running properly because your car might be running a lot more off the battery and not so much of f the alternator, but normally if the alternators bad it will drain the battery even if the cars not running.. Yes your first thing you would want to do is check the wiring and al that just because thats cheap and easy but most likley you wanna get the altenator tested...you can get that done at advance auto.. please rate me if you get a chance and if you have any other questions just let me know ill check up on your problem..
Thanks,
Steve
Jan 03, 2009 | 1996 Chevrolet Blazer
Vector Black And Decker High Frequency Automatic Battery Charger Logo
282 people viewed this question
Top Vector Tools & Hardware - Others Experts
Donald Beekman
Level 1 Expert
Charles Tidwell
toot tall
toot tall
Are you a Vector Tool and Hardware - Other Expert? Answer questions, earn points and help others
