Question about Lenoxx Electronics Clock Radio With CD Player
SOURCE: need help
their is nothing you can do yourself to repair this as it needs a new laser unit but the only thing you can do is take it to tv repair shop and they will fit a new one and get it recalibrated for sorry i couldnt offer you any more help................................
Posted on Oct 30, 2007
SOURCE: the cd will not play on the lenoxx sound cd player...
Have you tried cleaning the lens with a Cd cleaner disk?
Posted on May 24, 2010
SOURCE: Lenoxx compact disc player stero cassette
Does it fail on AC power, too? Motors draw a lot of current. Batteries may be weak.
Posted on Jan 18, 2011
Dec 02, 2012 | 2005 Mercury Grand Marquis
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Jul 12, 2011 | Televison & Video
Mar 02, 2011 | HHB BurnIt CDR830 CD Recorder
Dec 28, 2010 | Lenoxx Electronics CDR-190 Clock Radio
Sep 04, 2009 | Technics SL-MC50 CD Player
May 26, 2009 | 2004 Dodge Stratus
Jun 16, 2008 | Denon CDR-M30 CD Recorder
Oct 30, 2007 | Lenoxx Electronics CDR-190 Clock Radio
37 people viewed this question
