Question about Oxo Hardware & Accessories
What battery does an OXO small kitchen timer need?
What battery does a small kitchen OXO timer needs?
Nancy_GE
    Problem Solver:
  • 21 Answers
What battery does an OXO small kitchen timer need? - battery-oxo-small-kitchen-timer-need-b1enchklgluxhkaxylqpxcgq-1-0.jpg
I'm assuming you're referring to OXO's Magnetic Digital Timer model #1127980. The instructions require a CR2032 (coin-type) battery which is accessed by gently prying the battery cover off with a coin. You can download the instruction booklet here:
http://www.oxo.com/download/1183_gg_1127980_booklet.pdf
Posted on Mar 19, 2015
How to change the hour on the OXO triple grip timer.
The instruction booklet for OXO's Triple Timer Model ## 1071501 can be downloaded here:
http://www.oxo.com/download/556_gg_1071501_booklet.pdf
Mar 10, 2015 | Oxo Good Grips Triple Timer
Need to set clock on oxo timer
I also own this model, and the manual isn't availble on OXO's site. But this is what I've learned over the years:
To set clock:
  1. Press and hold clock/timer button for 3 seconds (clock icon will appear on left side of screen).
  2. Input time using keypad then quickly press clock/timer button to save.
To set timer:
  1. Press and release clock/timer button.
  2. If necessary, press clear/memory so timer reads all zeroes.
  3. Enter desired time using keypad (to a maximum of 99hrs:99mins:99secs).
  4. Press stop/start to begin countdown.
  5. Pause countdown by pressing stop/start; resume by pressing button again.
  6. When countdown is complete, timer will beep continuously for 30 seconds and display will flash. Timer will then beep every 10 seconds for 10 minutes until the stop/start button is pressed.
  7. Press clock/timer button to return to clock function.
To time activities:
  3. Press stop/start and plus (+) sign will appear on right side of screen as timer begins counting up.
  4. Pause count-up by pressing stop/start; resume by pressing button again.
  5. When you're finished timing, press stop/start to end timing function.
  6. Press clock/timer to return to clock function.
Sep 30, 2013 | Oxo Good Grips Digital Stainless Steel...
How to put a battery in an oxo magnetic timer
I assume you're referring to OXO's Magnetic Digital Timer model #1127980. The instructions require a CR2032 (coin-type) battery which is accessed by gently prying the battery cover off with a coin. You can download the instruction booklet here:
Apr 16, 2013 | Hardware & Accessories
OXO food scale shows erh code
I am having the same problem with the 5lb scale. Turned it on for the first time about 5 days ago and was ok. This morning when I went to use it it gave the ErH code. Would appreciate if any person has an answer. I am waiting for OXO to respond my e-mail.
Apr 14, 2013 | Oxo Good Grips 11-pound Digital Kitchen...
Reset cloock on oxo 3 timer
The instruction booklet for your timer is available for download here:
Feb 07, 2013 | Oxo Triple Timer
How to set oxo digital magnetic timer
For OXO instructions, you might try contacting the company:
Copy following link:
http://www.oxo.com/contactUs.aspx
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 10, 2012 | Hardware & Accessories
How do I set the clock on my oxo triple timer?
The instruction booklet for your OXO Triple Timer Model # 1071501 is available for download here:
Mar 13, 2011 | Hardware & Accessories
Hardware & Accessories Logo
269 people viewed this question
Top Oxo Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you an Oxo Hardware and Accessory Expert? Answer questions, earn points and help others
