DeLonghi CF210 Portable Air Conditioner Logo
A
Anonymous Posted on Jul 12, 2014
What are the mode of TCL room AC
I am un able to operate it properly
2helpful
2answers
How to fix CL display on TCL split-type Aircon?
HEALTH function (Optional)1. This function help carry away the accumulated dirt, bacteria, etc from the evaporator. 2. Turn off the air conditioner, press "CLEAN" button to enter this function and it will show "CL" on the display of indoor unit.
User Manual - TCL
https://www.google.com/search?q=TCL+split+type+Aircon+displays+CL
This is the best way to clean one with coil cleaner, a pressure washer and a funnel bag. Check out the videos.
How to Clean Split Air Conditioners (with Pictures)
wikiHow https://www.wikihow.com > ... > Air Conditioning
For the best clean, leave the spray on for 10-20 minutes. Finally, use a water spray to flush the unit and allow dirt to spill into the aircon bag. For help ...
2answers
I don't know where I control the volume on a TCL Roku TV Model 55R512 Remote. The TV is in mute mode and I can't unmute it.
On some TCL Roku TV remotes, pressing Volume Up un-mutes the TV. Pressing Volume Down enough times will mute the TV. (A few models have a physical Mute button on the side of the TV.) If the TV speakers have been disabled, you'll need to go through the Settings or Options menu instead. (If the unit was used with a sound system, that would be common.)
For more specific information, please add a comment with the TV model. Usually the remote instructions are in the TV documentation. I can't find any TCL TV documentation that lists the 55R512 remote.
I hope this helps.
My kenmore 12000 btu portable air conditioner keeps switching to DH mode out of AC mode
That means that it is dehumidifying. Is the air coming out still cold? I assume you have tried using the mode button to switch it back? Is the air extremely humid? Perhaps it is humid enough that the machine needs to dry the air before safely operating as an AC. The manual is available here:
http://www.sears.com/kenmore-portable-room-air-conditioner/p-04272012000P
Tcl service mode
Press & Hold Vol-ve and CH+ button together, then re-plug the TV to AC mains wall socket, with its ON/Off switch at ON state. This must make the TV to service mode. google.com/+GopakumarGopalan
2answers
I need service mode for TCL 21F5 model.... Pls help..
To enter service mode on a TCL 21F5 model TV, you will need to follow these steps:
  1. Turn off the TV using the remote control or the power button on the TV.
  2. Press and hold the "Menu" button on the TV.
  3. While holding the "Menu" button, press the power button to turn on the TV.
  4. Release the "Menu" button when the service menu appears on the screen.
Please note that making changes to the service menu can cause permanent damage to your TV if done incorrectly. It is recommended that you only make changes to the service menu if you are familiar with the settings and have proper knowledge of the TV's inner workings.
Also, It's better to check the manual or contact the TCL customer service for more details.
1helpful
Ok So We Bought This. But We Have A Problem Does It Take Water Or Not? Thats What I Need To Know! Please Help!
The DeLonghi PACA120E Portable Air Conditioner quickly cools rooms up to 400 square feet and comes equipped with several functions that make operation easy and low maintenance. Its 3 operating modes are supplemented with no-drip technology, an adjustable thermostat, 24-hour timer, and much more. This unit truly takes the work out of cooling medium- to large-sized spaces. Multiple Modes and Functions The DeLonghi A120E-also known as the Delonghi Pinguino PAC A120E-offers 3 operating modes and 3 additional operating functions that make this model versatile and energy efficient. Cool Mode: 12,000 BTUs of cooling power help cool large rooms, offices, or basements. Dry Mode: Reduce room humidity by removing excess moisture from the air. Fan Mode: Circulate air to keep your room comfortable without using a lot of energy. Low, medium, high, and an auto-speed are all included (auto speed selects a fan speed for you). Smart Function: Your AC uses Cool and Fan mode based on ambient room temperature. This function will also select your fan speed and keeps your room comfortable without wasting energy. Sleep Function: Using a low fan speed, the AC gradually reduces operation so your room remains comfortable but the AC runs more quietly and efficiently while you sleep. Boost Function: This function is ideal for the summer months and uses the maximum fan speed to rapidly reduce your room temperature. Useful Features Using DeLonghi's patented no-drip technology, this unit is "dripless" under normal conditions, meaning the AC will discharge all of the moisture collected from the air-so you typically won't have to worry about draining the water. When dehumidifying a lot of moisture in Dry mode, excess water may collect in the internal collection tank. Once the tank is full, the air conditioner will automatically turn off to avoid overflow damage. You can also use the included continuous drain hose as a no-fuss way to eliminate excess water as needed. An adjustable thermostat provides additional convenience by allowing you to set your room temperature. The DeLonghi portable AC will cycle on and off to eliminate over-cooling and maintain the set temperature. Additional Features Washable Air Filter: A washable air filter helps remove allergens and other particles from incoming air and saves you money on replacement filters. Quiet Operation: High efficiency compressor and components result in quiet performance. Electronic Controls: The LCD screen displays the timer and temperature settings, while intuitive indicator lights accompany each operating mode. 24-Hour Timer: This feature lets you program your AC to turn on or off up to 24 hours in advance, so it only runs when needed. Window Bracket: Double window bracket is included with purchase for flexible installation. Self-Diagnosis System: The unit includes a self-diagnostic maintenance system that identifies malfunctions should they occur. Remote Control: Use the full-featured remote control to change modes, set the timer, and select a fan speed up to 23 feet away from the receiver (on the front of the unit). Portability: Easy-roll casters and dual carrying handles make it simple to move this model from space to space.
My Haier 7000BTU portable AC unit is blowing hot air into the room from the back. We have the drain hose in and draining, so what might be the problem?
The drain hose is only to be used when the unit is in Dehumidifier Mode. In AC/Cooling Mode, there needs to be water in the tank to keep the coils cool. It is not recommended to use continuous drainage in AC Mode. My personal recommendation is do not operate Cooling Mode & Dehumidify Mode at the same time. As the dehumidify mode generates heat. Not something you need to be doing when you're trying to cool the room.
Hope this helped you and thanks for choosing FixYa.
10helpful
CODIGO PARA TV MODELO TCL
Buenas tardes,compre un televisor tcl mi abuela lo bloqueo la pantalla y no encuentro manera de desbloquearlaquiero saber si existe un codigo universal para desbloquearlo y no perder el aparato. Gracias de antemano pueden enviarme respuesta
25helpful
5answers
Help for TCL Brand of tv
I WANT THE SERVICE MODE CODE FOR MODEL NO: DP21E101 TCL TV 21"
Sharp Air Conditioner. Model # AF-S85NX. Does this A.C. fan cycle on & off in the auto cool mode or does remain on continuously. I need a small A.C. that cycles off and on with the compressor.
If you set you r AC to FAN mode the unit will not cool, it only runs in the indoor but the outdoor will off. If you set to AUTO the unit will cool but the indoor blower will automatically run slower when the room is cool or attain the room temp. setting. If you set it to COOL the fan speed is fix depending on your setting and it also operate in cool.
Top DeLonghi Heating & Cooling Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
