Whirlpool RBS275PD Electric Single Oven Logo
A
Anonymous Posted on Jul 12, 2014
Bake temp will not go past 325 - Whirlpool RBS275PD Electric Single Oven
Electrolux FPGS3085KFH oven takes excessive time to heat up. Sometimes need to turn on top burners to get oven to heat. Sometimes wont go past a certian temp unless i turn on top burners. ???
for bake there is one top and one bottom element,sounds like the top bake element needs replacing,do no confuse it with the grill element as there are two elements at the top the outer one is the bake
1helpful
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 • Dacor Ovens
2helpful
Wont heat past 200 degres
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 • Ovens
RE: Double convection wall oven (GLEB30T8ABA) Need to use timed bake option
Connie,
Found the owners manual but it was worthless didn't have the control board information.
Found the control board and it used in quite a few other makes has same functions on all the units.
So here's my best answer not your unit but is the same control board..
Sure hope this helps!?
https://c.searspartsdirect.com/mmh/lis_pdf/OWNM/1201522L.pdf
Best to you.
1helpful
Bosch HBN 642 -- single oven cycles and doesn't get above 325
WHAT WAS HAPPENING AT 1ST YOUR HI-LIMIT TERMAL SAFETY OR OVEN TEMP SENSOR FELT THAT THE OVEN WAS GET TOO HOT AND SEIZING OPERATION UNTIL SAFE TEMP WERE OBTAINED THIS IS GENERALLY A FAULTY OVEN TEMP SENSOR. I WOULD ADVISE YOU TO CONTACT A CERTIFIED TECH TO LOOK AT IT AND P.S. DON'T MENTION THAT YOU TOOK THE MACHINE APART MOST SERVICE COMPANIES WILL NOT SERVICE THE MACHINE IF IT BEEN TAMPER WITH BY THE CUSTOMER DUE TO INSURANCE AND LIABILITIES
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
May 28, 2008 • Ovens
1helpful
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
