LG CU500 Cellular Phone Logo
Question about LG CU500 Cellular Phone
Set voice mail message for lg cu500 - LG CU500 Cellular Phone
Mismatch of application settings no voice mail. how to fix
some phones have virtual voice mail...which means you must syc it with the service voice mail ... if voice mail is pass word protected ...you must program the voice mail password and information into the virtual voice mail or it will not retrieve messages or give you notification of incoming voice mail.. The directions they give you for this is really asinine and hard to understand. Call your service provider they will be able to help you.
3answers
LG KG290
Call "077" to listen to messages received. Follow the voice instructions to change your voice mail settings.
How do i retreive my voice mail messages
hold the #1 down until it dials your voice mail for you, then listen to messages. push 7 to erase one & push 9 to save one after you listen to them. Phone does not come with voice mail set up already, so if this is a new phone for you, you will have to dial 1 & hold button down until it rings & it will walk you through setting it up
Wont tell when I have a voicemail
you have probably turned off the voice messaging indicator, log into your voice mail and choose the number option for voicemail settings/options and then make sure that the voice messaging indicator is set to on
1helpful
I lost the password to my voice mail on a tracfone. How can I change the password to something that I can remember?
Tracfone support should be able to reset your voice mail. You will loose all your messages due to privacy reasons, and will have to set up new voice mail from the phone, not alternate line.
4helpful
NEED TO SET UP MY VOICE MAIL
Hi,If your account is enabled for voice mail, you can receive voice messages in your Inbox and also in a text message on your mobile phone. Both the message in your Inbox and the text message will include a preview of the voice message in text.
How do I set up voice mail?
1. Go to https://outlook.com to sign in to your mailbox, go to Options > Voice Mail tab, and then click Set Up Now.
2. When you set up your voice mail:
* You'll register your mobile phone number.
* Text messaging is set up. You can choose to be notified in a text message that you have voice mail or have missed a call.
* Call forwarding is set up so that your mobile provider forwards calls you receive to your voice mail. So if you don't answer your phone, your phone is busy, or you're unreachable or unavailable, the caller will be sent to your voice mail. After your personal greeting is played, the caller can leave a voice message for you.
* You can test whether your voice mail has been set up correctly by dialing your mobile phone number from your mobile phone. This verifies that call forwarding is correctly set up with your mobile provider.
How do I change my voice mail after I've set it up?
After you've finished setting up voice mail, you may want to:
* Change the mobile provider's voice mail number so you can use the key your provider has reserved for accessing voice mail to access your voice mail. For details about how to do this, see Changing the Number You Call to Access Your Voice Mail.
* Create a contact on your mobile phone. For details about how to do this, see Create a Contact for Voice Mail.
* Assign a speed dial key to the contact you create for Outlook Web App voice mail. For details about how to do this, see Set Up Speed Dialing for Voice Mail.
What else do I need to know?
* The voice mail service is available only to certain customers in certain regions. If you can use voice mail, you'll see a welcome message in your Inbox telling you how to set up voice mail for your account.
Thanks for using fixya...
Jan 20, 2011 • Cell Phones
I have a kg800 chocolate. Help with voice mail
it shoudl go in to you messaging box and be ina voicemail folder and tell you if u have 1
1helpful
2answers
Not sending sms txt on LG KS20 but can receive...please help
To fix this problem is you need to borrow/own a phone that is from your service provider that isn't touch or 3G phone. I used Nokia 5200 or Nokia 5300.. Same phones
Change the number for Voice mail.
(Your Cellphone Number) then put your Voice Mail # on your Text number where you receive your Text service SMS. Make sure both # has the +1 at the start.
Hope this help...
1helpful
Hi....I have Tmobile and i just bought an LG KS20 but for some reason i cannot send any sms text msg but i can receive. Please help
Another thing that helps is getting your text message and voicemail number. I requested it from T-Mobile since they are my service provider and have then shut down your network (phone off, battery out) after you are done.
(Settings - Phone- Services - Voice Mail and Text Messages - Get settings - then putting in the correct text messages service center number and voice mail)
It worked for me right away.
Voice Dialing
voice dial number is depend on operetor. in ur phone goto menu-message-(setting) voice mail server
Top LG Cell Phones Experts
David Shaub
George Etukudo
W.L.
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
