Question about Lenovo 3000 C200 Notebook
Error 0701 usb - Lenovo 3000 C200 Notebook
Alex
    Champion:
  • 207 Answers
Check that you do not have any bent pins in the USB connector. If a USB stick/device is inserted a bad way, then you can bend the pins in the connector.
Posted on May 13, 2015
5 Related Answers
Anonymous
SOURCE: Error 0701: USB Over Current On HC/Port - Bus:00H Dev :1DH Fun:01H / Port:00H
pls solve
Posted on Sep 19, 2008
Anonymous
  • 33 Answers
SOURCE: Error 0701: USB Over Current On HC/Port - Bus:00H...
Try connecting your USB peripherals through a mains powered hub.
Posted on Dec 02, 2008
Anonymous
SOURCE: error 0701- usb over current on hc/port
This is not a big problem if the tablet works. There are three simple possible solutions to this problem:
1) Sometimes you can plug USB devices into a wall socket so you don't rely entirely on the USB power. See if the tablet can be attached to another power source - if so use the appropriate power adaptor to plug it into a wall socket.
2) Very few USB cables are designed to carry much current. This design keeps the USB cables thin and flexible. Try purchasing a USB cable that looks like it can carry the extra current. Unfortunately USB cable manufacturers do not display how much electrical current their cables can deliver efficiently, so you will need to guess. Generally the thicker cables can carry more current - these cables are *not* necessarily the expensive gold-plated ones. You can usually find a thick cheap one that will do the trick - but it will take a little experimentation. Try different thick USB cables to see if one makes the problem go away.
3) get a special USB cable that takes the power from 2 USB ports and delivers it to one device. These are strange looking USB cables that have an extra male adaptor cord hanging from a USB cable - the cable has 2 male adaptors and 1 female adaptor. Of course this will take up two USB slots on your USB hub.
Hope these help!
Posted on Sep 12, 2009
Anonymous
SOURCE: error 0701: USB Over Current
Error 0701: USB Over Error 0701: USB Over Current On HC/Port - Bus:00H Dev :1DH Fun:01H / Port:00HCurrent On HC/Port - Bus:00H Dev :1DH Fun:01H / Port:00H
Posted on Nov 08, 2010
reyronald238
ron olf
  • 57 Answers
SOURCE: Experiencing following on boot: Lenovo
Kindly set the BIOS on start up. You may have disabled the USB. If the matter persists then check the drivers in the device manager if they are correctly installed. Or if the problem is your Operating System then have it updated by installing online updates. This would install necessary drivers. If the problem still persists then, look for a computer technician to check your laptop.
Posted on Jan 31, 2011
Usb over current
Fuse or supply chip has failed. A repair to the mother board is required.
Jul 24, 2013 | Toshiba SATELLITE A100-TA2 LAPTOP LCD...
Error 0701: USB Over Current on HC/Port
Sep 28, 2010 | Lenovo 3000 C200 Notebook
Usb over voltage error 0701
This likely indicates that your USB device(s) is drawing too much power from your USB bus. A possible solution is to purchase a powered USB hub that will draw power from an A/C outlet in your house.
Mar 10, 2010 | Compaq Presario 5000 PC Desktop
Error 0701 problem in lenovo laptop 3000 c series and N
Try turning on the computer in safe mode and turn on the computer by pressing f8 and see if that works. check in the bios if the cd drive is detected make sure that the disk you put in cd drive is a bootable disk
Jan 09, 2010 | Lenovo 3000 N100 Notebook PC
Error 701 appears on the screen. no booting at all. all dead.
hi the laptop v3000 comapq pesario teh error code 0701 usb not working . witch smd has the problem
Jun 19, 2009 | Computers & Internet
0701 usb over current on hc/port error
I had the same problem on a toshiba satellite u400.
Usb over current on port ... blabla..
Please press F1 to resume or F12 to install.
F1 just ended up in a screen asking to press F2 or F12 which did nothing.
F12 did nothing.
Rebooting the pc ended in a black screen with a flickering HD symbol.
To be able to boot again on the BIOS I had to remove the battery and disconnect the plug.
Once It restarted booting on the error USB over current.
Si I took a USB mouse and tried to boot with the mouse plugged in on port , then another ... at the third port the PC booted normally with no error :)
Don't have any idea why it became faulty but it's now solved for me.
Mar 12, 2009 | Toshiba Satellite A135-S4527 Notebook
Dec 02, 2008 | Lenovo 3000 C200 Notebook
Hardware problem - not booting into windows
One of your usb ports is either damaged or has an object stuck in it causing a short. Unplug all usb devices and look at each port. Note if one looks slightly different from the others. There is a plastic tab that fits into usb plugs. If this tab is bent and touches the side of the port, it can cause the short. If this is the case you may be able to either clean out or bend back the bent tab.
Sep 08, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
tosrisri hello,
If you have a VISTA DVD, please insert it, and use the BIOS to boot through your CD.
Then, when the VISTA installation comes up, press repair. Restart, and try again. Please report back.
Aug 09, 2008 | Lenovo 3000 C200 Notebook
Lenovo 3000 C200 Notebook Logo
106 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Toby Lee
Toby Lee
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
