The touch screen seems to be off - I cannot access the left side of the screen. I hit the letter A and get the S. And I cannot use the back button as it is located on the far left.
Just had same problem - answers here are close - but not quite right for the nuvi 2597 LMT
I finally managed to reach the calibration screen by rebooting as follows:
- shutting down the nuvi (long press on power button)
- pressing on top LHS of screen and hold down power button at same time.
- keep holding until SYSTEM" appears in small type, scrolling just above the Garmin logo. At this point, release the power button, but keep pressing the top LHS of screen.
- after c.20sec, the calibration procedure begins...
Try poweing it on while holding the upper left corner.
SOURCE: Garmin Nuvi 350 Calibration Issue
Turn the unit off. Press and hold down the power button and keep holding it. You will see the screen light up and it will say "pre-boot mode". Keep holding down the power key. It will then say "booting". Keep holding the power button down. You'll then come to the calibation screen. Select the dots and you'll be back in business.
- Jim
SOURCE: my garmin nuvi 670 touch screen is not calibrated
Have you tried using the screen calibration command? Press the Wrench symbol, then the Display symbol and then Calibrate screen. Press the dots as it tells you to and you should now have a calibrated touchscreen.
- Jim
SHARCNET- USA
SOURCE: Cant calibrate my Garmin Nuvi 255 GPS
You have the wrong procedure. Please see this link:
http://www.sharc.net/discus/messages/6/77.html?1236709210
- Jim
SOURCE: garmin nuvi 1350:touch screen calibration
Hold your finger on the top left corner of the screen while turning it on. Release the power button when you see the Garmin logo pop up but keep your finger on the top left corner until the white calibration screen shows.
SOURCE: garmin nuvi 200 wont calibrate
Yup, same problem. All it took was holding the power button to the left for about 30 seconds and the calibration screen came up. Problem solved!
