Question about Altec Lansing ADA425 3-piece 30-watt Speaker Set Computer Speakers
Z3 logitech 9 pinPinouts - Altec Lansing ADA425 3-piece 30-watt Speaker Set Computer Speakers
Something is draining the battery on our 2002 bmw z3.the battery and alternator checks out good,what is draining the battery??
HELP 2000 Z3 Battery Drain - Bimmerfest - BMW Forums
www.bimmerfest.com > ... > Z Series > E36/7 Z3 (1996-2002)
Feb 18, 2007 - 7 posts - ‎6 authors
HELP 2000 Z3 Battery Drain E36/7 Z3 (1996-2002) ... Something is draining the battery. ... Posts: 55. Mein Auto: 2000 BMW Z3 2.8 Roadster. z3 1.9 battery drain (fuse 31)
Apr 9, 2013
Intermittent car battery drain problem NEED HELP
Jan 29, 2013
Mysterious Battery Drain
Feb 23, 2008
Battery drain....after 2 days sitting dead...
Mar 28, 2006
More results from www.bimmerfest.com
Jan 18, 2016 | 2002 BMW Z3
Tappet clearence for honda reborn 2010
reborn>? need model car and engine option.
k20, H22, K23
what engine, what country was car sold to... (market)???
ah, its a civic
tappets?
1.3 L LDA-MF5 I4, IMA engine (Hybrid)
1.4 L L13A7 I4 (European model only)
1.6 L R16A1 I4
1.8 L R18A1 I4
2.0 L K20Z3 I4 ( some USA cars use this) this year.
2.0 L K20Z2 I4
2.2 L N22A2 I4 turbodiesel
2.4 L K24Z5 I4 185 hp
the USA variant is K20 with or with out VVT.
there are 9 K20 engines.
z2,z3, z4 sub versions. in 2010.
for version of k20 that do have solids.
the lash is. USA, Z3 spec engine.
intake 0.0012-0.0022"
exhaust. 0.0022-0.0031
i logged in to alldata.com and read that, so can you,or buy the honda FSM over the counter.
the choices, on my usa listing was
LDA2 1.3L
R18A1 and A4
K20Z3
I tossed coin and landed on Z3,
Dec 03, 2013 | Honda Cars & Trucks
Logitech z3 wiring
I have a logitech z3 subwoofer with a mini-DIN-9 connector socket. It also has a volume control and 110V power cord. As best as i could trace the circuit, and using the TDA7377 stereo bridge amplifier chip datasheet, the pinout for the mini-DIN is as follows (untested):
1: L in (to vol.)
2: R in (to vol.)
3: Power (12V from transformer)
4: Standby (5V to play, 0.05mA; 0V to standby)
5: L out
6: R out
7: Ground
8: Ground
9: Ground
Connecting 3 to 4 with a large resistance (~20K ohms) should enable speaker. Pins 1 and 2 might be swapped; pins 5 and 8 might be swapped. Mini-DIN socket pin holes are numbered right to left, bottom row to top row:
9 8 7
6 5 4 3
2 1
Sep 03, 2012 | Logitech Z3 2 Speakers
I was trying to connect my logitech z3 to my laptops music output but it only mutes my computers sound and does not play it. Device is ON. I'm running windows 7 but it shouldn't cause any problems?
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker you might have to configure them then select properties you will see tabs general level in this tab make sure your setting are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
hope this helps W7
Aug 12, 2011 | Logitech Z3 2 Speakers
I just bought a logitech web cam. It works but theres white lines appearing like in a "rain form" matter when I'm web camming with friends. How can I fix this?
Make sure you have Microsoft DierectX 9 or later installed
Failing that, re-install the latest software
Visit the Logitech website and browse the photo gallery for your model and click on the photo to navigate to the support page.
Note - Older models on page 2 - look for the link at the bottom right of page 1 and click on it "Still can't find your product?"
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
In addition to the Logitech installer you will need to download DirectX 9 or later to support your webcam
Jul 22, 2010 | Logitech Quickcam Chat Webcam
Logitech x-230 9 pin problem . i need to manualy insert wires into pin holes.. So can anyone tell me the color and pin hole nunber to put right wire into
worked on this for 3 days but i finaly got it I had to open it an follow coper lines using datasheet, the connector is RS232 the pins are
1 = LED+
2 = IN R
3 = OUT R
4 = OUT L
5 = GND
6 = ON
7 = 5V
8 = GND
9 = IN L
so you have to put a swiths between pin 6 and 7
you should also put a potentiometer GND-IN-(AUDIO SOURCE)
and a led between pin 1 and GND
and that is it!
---POXTRON---
May 15, 2010 | Logitech X-230 Computer Speakers
I have logitech speakers for my computer. I need a new cable that goes from the bottom of the bass speaker to the two smaller speakers. A couple of the pins are broken on the plug that plugs into the bass...
logitech rarely has replacement parts. and for this model is not for the u.s. distribution so youcan not even call u.s tech support for help. try ebay or craiglist. if the connector is not proprietary you might be able to get a electronic repair shop to repin the connector.
Jul 24, 2009 | Logitech Audio Players & Recorders
I have a 2001 Z3 and I have the radio code but I cannot enter is as there are only buttons labelled 1 to 6 and my code required the digits 7 and 8 to be entered. How do I know which buttons are 7 and 8?
This works for our Z3 radio:
example, code 3749. To set the first digit (in this case, 3), press button 1 three times - the digit 3 should appear in the display. To set digit 2, press button 2 seven times and 7 should appear in the display. To set digit 3, use button 3 (in this case, pressed 4 times) and to set digit 4, use button 4 and press 9 times. When all 4 digits are correctly displayed, press the set button, which is the furthest button on the right and has an arrow pointing to the right. The radio should now work. Good luck, Ian
Mar 17, 2009 | 2001 BMW Z3
Top Altec Lansing Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
