My model is the psp511lca but it may be the same type of reset. I have a dial I turn to the "change filter" option and then press the up and down temperature buttons simultaneously and hold for a few seconds. When you turn the dial back to "run" the change filter light on the display is gone.
To reset the air filter indicator:
1. Open up the control panel and turn the dial to "Air Filter"
2. Press the temperature up and down buttons simultaneously
3. Turn the dial back to "Run"
If you forget these instructions, you can find them in the owner's manual. You can download the manual here:
RESET FILTER COUNTEROnce you have replaced your filter, the filter life counter is reset back to its fullamount remaining value by turning the dial to AIR FILTER and pressing the UPand DOWN buttons together at the same time. NOTE: The counter is also reset bychanging the filter setting value, as described above, to a different number ofdays.
hello cwest....
If your thermostat is reading Celsius instead of Fahrenheit press the 'Set Time' & 'Hold Temp' buttons at the same time to toggle it back to read Fahrenheit again. J.
