Question about Altec Lansing VS2121 Computer Speakers
Bendix ef8953005428 jeep pin wire digram - Altec Lansing VS2121 Computer Speakers
Tachometer doesnt work 1990 jeep wrangler
ok what engine?
2.5L , 4.0L ? 4.2L
the tacho works by spark, signals and this varies by engine type.
1990 has the very odd, French REnix ECU (bendix-renix)
with no scan tool suport ,until 1993.
so scanning it for tacho signal good, is impossible. (DIY)
i sold min long ago. at 250k miles. now have 5 th jeep, 2008, a retired tech.
sold it with those rare books too. all 3 sets.
back then the engine has a small blue book, separate from main FSM.
ebay has them if patient, id recommend owning the FSM on any car
you do the work on. why work blind?>
alldata.com may have these facts.
too bad you didnt post engine. really, so ill will wild guess its a
4.2L
and answer for that.
the ignition model sense the spark signal to the Tacho
the tach is 3 pin meter. power, ground and signal.
if the signal is good and 12vdc across, power and ground pins
the tacho is bad.
if power and ground are bad fix that first.
if the signal is dead, the wire is cut or grounding out or the ignition wire
green is dead.and bad module,
on the 4.2L the green wire. goes dead kills the coil dead..
since it runs ok
that leaves way.
bad power to tacho, bad tacho.
easy peasy. this car.
other engine can work differently, (not stated)
Jun 01, 2014 | Jeep Wrangler Cars & Trucks
I need wire 4 pin mic to a 5 pin mic cobra 142 Gtl?
you'll have to seperate the ground from the shield and then attach the rx,tx,and ground ,the shild then the ground thats on the shield.
Apr 30, 2014 | Connex Radio Communications
I need to know what the wires on the back of altenator go to
View of the alternator electrical connections-(A) battery positive, (B) field terminals, (C) wire harness hold down, (D) ground terminal
Dec 15, 2011 | 1998 Jeep Cherokee
Need pin locations for analdl connector for a 1996 pontic grand am
Below is a wirinf diagram for the plug. I wasn't sure which engine you had so I went with the 3.1 liter engine. If you need the one for the 4 cylinder or if you need this one bigger (this is the largest I can post on here do to size limits) you can email me at [email protected] but remind me of the make model year and engine size. Hope this helps.
Nov 16, 2011 | 1996 Pontiac Grand Am
I need the wiring diagram color codes on a 2010 jeep liberty to hook up a hi low converter which conveniently came with no instructions please hel p
Autozone.com should have wire digrams in the repair section. They are free. All you need to do is register which is also free.
Sep 18, 2011 | 2010 Jeep Liberty
Digram for a 2004 jeep fuel pump put a new fuel pump on but it will not come on and fuel gage not working were is the ground wire located
The ground wire is in the wire harness that connects to the fuel pump. This sounds more like the relay is bad. Check the relay under the hood. Your model also has a fuse that can pop and cause the same issue.
Jun 16, 2011 | 2004 Jeep Grand Cherokee
Need wiring digram from spark plugs to distributor cap
Review the Jeep ZJ Repair Manual in the Firing Order (page 10 and 11) for 4.0L 6-cyl and 5.2L 8-cyl.
I really hope hepled with this (remember rated this help) Good luck.
Nov 18, 2009 | 1997 Jeep Grand Cherokee
Altec Lansing VS2121 Computer Speakers Logo
112 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Sharps s
Ekse
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
