Question about Altec Lansing VS2121 Computer Speakers
Bendix ef8953005428 Wire digram for pin no on computer
Why won't the high beams stay on when the stick is clicked forward?
The pin switch a broke or stuck in replace the switch but I have to see wire digram to be 100 sure and do some tests
Oct 21, 2015 | 2004 Oldsmobile Alero
Mic wireing washington
1 audio, 3 receive, 4 shield, 5 transmit (2 MAY have to be jumped with 4) Audio wire is wrapped with the shield wire, so that eliminates 2 of the 4 wires. put 1 of the 2 remaining wires on pin 5 and plug it in ..... if it starts receiving, you can put the remaining wire on 3........ IF IT KEYS UP WHEN PLUGGED IN..... switch the wire with the other remaining one :-)
Aug 17, 2014 | Radio Communications
I need wire 4 pin mic to a 5 pin mic cobra 142 Gtl?
you'll have to seperate the ground from the shield and then attach the rx,tx,and ground ,the shild then the ground thats on the shield.
Apr 30, 2014 | Connex Radio Communications
Need pin locations for analdl connector for a 1996 pontic grand am
Below is a wirinf diagram for the plug. I wasn't sure which engine you had so I went with the 3.1 liter engine. If you need the one for the 4 cylinder or if you need this one bigger (this is the largest I can post on here do to size limits) you can email me at [email protected] but remind me of the make model year and engine size. Hope this helps.
Nov 16, 2011 | 1996 Pontiac Grand Am
I need a wiring digram for a rk 56 inside the mike my wires are broke need to know were to put them back connex 3300hp
  • With the switch sitting as it is in the picture below (actual switch recessed tho the right. Soldier the wires in this order.
  1. Black
  2. Red
  3. Lite Blue.
  4. Dark Yellow (This yellow wire comes from the mic cord itself)
  5. Shield.
  6. Lite Yellow. (This yellow wire runs off to the side of the mike to the electrical components inside the mic)
  • Standard 4 pin Cobra mic tip to run it to that Connex.
  • Pin 1 - Shield.
  • Pin 2 - White.
  • Pin 3 - Red.
  • Pin 4 - Black.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 05, 2011 | Connex 3300 240-Channels Base CB Radio
I have a hand held D104-M6 and I can't find the
I'm not sure if this will help but I'll try
Pin 1-Blue and Sheild
Pin 2- White
Pin 3- Red
Pin 4- Black
Hope this helped,all Astatic mics are wired the same.
Jun 22, 2011 | Astatic Radio Communications
7 pin connector
I don't know what this means, "car discharges dont shift right so i unpluged it the car charges".
but did you verify the transmission computer - TCU or TCM - is correct?
Dec 21, 2017 | 1994 Pontiac Trans Sport
Altec Lansing VS2121 Computer Speakers Logo
60 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Sharps s
Ekse
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
