SOURCE: Installing a spring in the Timex Ironman WR 100M watch
That spring is called COIL SPRING and it transmits the signal from the microprocessor to audio membrane fixed to caseback. This is how you hear all the beeps, alarms, e.t.c.
Examine watch movement and you should fine small hole (it can be even marked with an arrow and writing: COIL SPRING).
Fit that coil spring in to the hole and close the caseback. If you hear no sound, you fitted it in the wrong hole, so, refit the coil spring till you find the right hole and hear the beeps.
Rate, please.
SOURCE: I need a replacement resin
Welcome to Fixya.
This is where you can find/order a replacement watchband for your Timex Ironman watch :
Timex Ironman Bands
Thanks for using Fixya
SOURCE: What's your problem I need Timex WR-100M manual
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
The WR-100M is not actually the model number of your watch, but rather only an indication of the Water Resistance rating of that particular model (100 Meters) and is found on many different models of Timex watches. You should be able to find the actual model number on the back of the watch under the strap.
Here is a direct link to the TIMEX SUPPORT page where you can download the appropriate USER'S MANUAL for your particular model of TIMEX watch:
http://www.timex.ca/en/manuals.aspx
Just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the complete list of available TIMEX Watch Owner's Manuals for you to download.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you Russ.
Good luck and take care.
Joe.
SOURCE: How do we set time on casio wr-100m
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
SOURCE: how to set time jaga 100m
It's described here: http://support.radioshack.com/support_radios/doc40/40189.htm
