SOURCE: cub cadet lt1050 poor running
when you cleaned the carb was the needle replaced. also what is the compression on this engine. if a unit has low compression they will sometimes only run on full choke. is there good fresh gas in this unit. No water..(if in doubt trow it out)
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
SOURCE: how to put a belt back on a cub cadet lt1050
Take the belt and apply axle-grease to it alllll over. apply large amounts of grease to each pully - and then just slide it on.
SOURCE: i have a LT1050 cub cadet and my blades won't
When you say you have 14.4 volts to the clutch, is that measuring voltage from one terminal to ground? or between terminals. If you actually measured at both therminals, then a bad ground would not be an issue. With mower off, remove wires from clutch terminals. With ohm meter check resistance between terminals, if you have none, then clutch is bad. Also check each terminal to ground, it should be open to ground.
