Question about Bunn GRX-B
My bunn 10 coffe maker just died
B10 cup coffee maker just died it will not brew or make hot water
Thomas Aldrin Nullas
    New Friend:
  • 128 Answers
Not brew if no water coming in to filll the tank
Posted on Oct 02, 2014
5 Related Answers
Anonymous
SOURCE: my bunn is too slow
Use the de-liming spring to clean the copper tube behind the spray head. Pour several pots of clear white vinegar through the unit to further remove lime and scale from the interior of your coffee maker. My Bunn is 24 years old, and the only replacement parts I've ever required are new carafes and the 4041 silicone washer repair kit.
Posted on Sep 19, 2007
Anonymous
  • 125 Answers
SOURCE: Bunn Coffee maker leaks
Hi, you can go to www.bunnomatic.com, and select for home or commercial units, and get an 800 number to call for service and parts. If they cannot help you a appliance repair shop should be able to get you going, thank you.
Posted on Jan 04, 2009
Gord Thurston
  • 131 Answers
SOURCE: bunn commercial coffee maker plug overheats, no hot water
Most likely this is your heating element, but it could also be your main thermostat
Posted on Feb 13, 2009
Anonymous
  • 4 Answers
SOURCE: my 10 cup Bunn coffee maker leaks from the top
I have the same problem and I took the coffee maker apart to find out why. It has to do with a leak on a fitting. On mine I found that the fitting where the hole in the black plastic that the water flows through to get into the stainless steel tank needed to be repaired with some silicone sealant to fix the leak. Still making some coffee!
Posted on Oct 15, 2009
Anonymous
  • 40 Answers
SOURCE: Coffee grounds overflow out of basket into top of coffee pot.
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Note: Some coffee makers define as little as 5 oz as a cup.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
Posted on Jan 04, 2010
BUNN MY CAFE BAD TAST WITH COFFE OR HOT COCO
Try really cleaning the basket that the water and coffee or cocao goes into. If you don't really clean it well, it will have the taste of the last thing brewed mixed in with the new brew. Coffee followed by coffee should not be a problem, but coffee followed by cocao will give the cocao a coffee taste, and visa versa.
Nov 21, 2013 | Bunn My Cafe MCU Universal 4-in-1 Single...
My Bunn coffeemaker is leaking water after it stops brewing and the coffee doesn't seem to get as hot as it once did. It also only gives back 4 cups for a 6 cup brew.
if you unscrew the top there's a rubber seal in there that you might have to replace that causes the leaks. also clean your coffee maker regularly with vinegar.
my husband had to replace the seal in ours 4 times but after owning the same Bunn for 20 yrs it was time for a new one
Jan 18, 2011 | Bunn 10 Cup Home Coffee Brewer
I have a Bunn B10-B. i put in 12 cups of water get 9 cups of coffee and water all over the counter.
Please call customer service with the model and date code from the bottom of your unit. The number is 800-352-2866.
Dec 26, 2010 | Bunn B10 Coffee Maker
My bunn coffe maker leaks water from the bottom I get only 8 cups not the 10 can it bbe repaired
If you will call Customer Service at 800-352-2866 with the model and date code we can further assist you.
Aug 14, 2010 | Bunn 10 Cup Home Coffee Brewer
Will not percolate. Water is poured, it heats up, no coffee brew
Bunn Home brewers don't perculate. They work the same way that commercial brewers do. Fillit with water, let it heat for about 20 minutes, then put your filter and coffee grounds in the funnel, pour a pot of water into the machine, put the pot on the warmer, and let the water run through. Then enjoy a nice hot cup of coffee.
Apr 12, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
Bunn home coffee maker is leaking from the top model #B10-W and the date code is 042302
take the top off there is a little oring where it takes water replace oring hardware store
had the same promlem
Feb 24, 2010 | Bunn 10 Cup Home Coffee Brewer
When I put in, 6 cups of water, if the 10 cup Bunn coffee maker after it has sat overnight, it only expels about 4 - 4.5 cups. I don't think it can all be evaporating or being absorbed in the grounds can...
look for water leaks around pot. Otherwise do a daytime brew to compare your difference between the amount poured in and what comes out. Please note that less water should mean using less ground coffee. Suggest 1 heaping table spoon per brewed cup.
Feb 10, 2010 | Bunn 10 Cup Home Coffee Brewer
Coffee grounds in bottom of commercail size coffee maker
If you will call 800-286-6070 we can help you with this.
Nov 01, 2009 | Bunn 10 Cup Home Coffee Brewer
My bunn is too slow
Sep 15, 2007 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn GRX-B Logo
418 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
