Question about Pride Victory 4 Wheel Mid-Size Electric Scooter
What does the 7 beep code mean on my Victory Pride 10 mean when I turn the key on ?
Rob Hill
  • Pride Master
  • 1,414 Answers
Hi , 7 bleeps is the throttle pot error , either a calibration problem or a faulty pot, i can help you , please contact me
Regards
Rob
www.gewizrepairs.co.uk
Posted on Jul 10, 2015
2 Related Answers
oregoon
  • 175 Answers
SOURCE: THE SCOOTER MAKES A HIGH PITCH NOISE WHEN THE KEY IS TURNED ON
The buzzer is a piezo-electric device that is the "horn" for the scooter. It also will alert when the scooter is in reverse, if this option is programmed into the scooter. It receives its power from the PC board or console board which is located inside the top of the shroud at the tiller, where the thumb paddles that direct the scooter are located. If liquids have reached the board, or if condensation has affected the board, the circuit that controls the buzzer may have shorted causing it to come on constantly.
Opening the top of the shroud is fairly simple. Remove about 6 screws holding the clamshell cover together, remove the speed adjust knob, and it should come apart. Inside you'll see a PC (printed circuit) board, green in color with lots of small electronic parts embedded on it. The buzzer is also inside, usually about the size of a marshmallow and black in color with tiny holes to let the noise escape. There will be two wires leading from the buzzer to the plug-in at the PC board. Unplug the buzzer and the noise will stop, but you won't have use of the "horn" at all. Replacing the PC board can be done by a certified Pride tech, but it will probably cost you about $150.00 for parts and labor.
Hope this helps.
Posted on Jul 07, 2009
Colin Taylor
  • 347 Answers
SOURCE: I have a 3 Wheel
Hello,visit:www.alldatasheet.com.Download as a PDF File-SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772. This is 36 pages,being you have a scooter you only need pages 1 to 18.19 to 36 covers wheelchairs.Download it to your Adobe reader,save & print for future ref.And good news the site i gave you[alldatasheet.com] is free,The job you need to to is quite easy as you will see,a tip though,take pics with ur mob,just to be sure in case you forget how things are,hope this has helped,im disabled myself & know what its like not to be moblie MERRY XMAS Colin.
Posted on Dec 16, 2010
Turn on. Won't go. Six beeps. What's wrong?
hi ring pride 1-800-800-8586 about youre problem It could b a fault with youre control box ......good luck
Nov 29, 2015 | Pride Mobility Products Pride Victory 10 -...
Scooter is saying error code 8 which is motor does anyone know what this could be please?
Pride Mobility Products Victory 9 Scooter 4 Wheel Error code
www.fixya.com > ... > Pride Mobility Products Victory 9 Scooter 4 Wheel
Pride Mobility Products Victory 9 Scooter 4 Wheel, error code related issues. ... Question about Thermometer Mobility Scooters ... error code is 8 Error code 8 means an internal controller error or problem and requires replacement of the controller. ... Theysay there is no listing for code 9 I have replaced the batteries,checked .
Basic Troubleshooting Instructions - Pride Mobility Productswww.pridemobility.com > Resource CenterPride MobilityScooters. INFINFB2040 Sonic Troubleshooting ... Chargers. INFINFB2586 Charger Indicator Codes ... Disclosure Statement Pursuant to Cal. Civ. Code 1714.43(a)[PDF]Legend Owner's Manual - Pride Mobility Products
Nov 28, 2015 | Pride Health & Beauty
I REPLACED THE THROTTLE CONTROL ON MY PRIDE V10 SCOOTER AND RIDING IN GRASS IT STOPS AND BEEP 6 TIMES
6 beeps =
Throttle lever (pot) is not in center position. Return throttle lever
to center position, then turn scooter OFF then ON.
Mar 07, 2015 | Pride Victory 10 3-Wheel
Pride victory 9 beeping 7 times won't Move
Go to Pride mobility web page and get the manual for your model . The codes and their meanings are described in the manual
Sep 23, 2014 | Health & Beauty
What does the 7 beep code mean on my Pride Victory 10 scooter mean when I turn the key on ?
This is a speed pot or throttle control problem (wig-wag) have you had some speed issues with the scooter before this happened, if so the wig-wag needs replacing. Make sure it is in the centre position at rest and switch the scooter on again.
Jul 11, 2014 | Pride Mobility Products Pride Victory 10 -...
I have a 3 Wheel Pride Victory 10 Scooter. It has been beeping multiple times when turned on and it will not go forward. When I pull the lever just a little bit and then turn the key on it does work. The...
Dec 16, 2010 | Pride Victory 4 Wheel Mid-Size Electric...
Pride Victory 4 Wheel Mid-Size Electric Scooter  Logo
162 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
