Question about Dometic Rooftop RV Air Conditioner
Dometic roof top rv ac not cooling
Model 620426.331. Fan runs great. Not cooling. Have cleaned under shroud checked fuses on panel. Any other help would be appreciated
Posted by Henry McCary on
George Merkley
    Scholar:
  • 194 Answers
Sounds like it is low on freon have someone check with gage and add more if nedded.
Posted on Jul 11, 2014
Runs/cools great unless outside temp gets in high 80s
try replacing capacitors. or communication cable issue to that a/c
Jun 25, 2013 | Dometic Rooftop RV Air Conditioner
My Dometic roof top ac doesn't cool. Fan runs fine, no COOL air. With thermostat in off position. Checking the voltages I found 118v at the breaker. At the run relay, 118v going in and a coupl
Please reply with Model number of bottom of AC unit ( upper) . Can be seen from inside usually. Thermostat model, plus if controls are at the ceiling assy or at thermostat on wall.
Jan 17, 2013 | Dometic Rooftop RV Air Conditioner
Not cooling
check the and see if the condenser fan is running. you will find it if you take the top off also check and see if the condenser coil is clean. if it is dirty or the fan under the top is not running it will cause the compressor to short cycle on limits or overload.
May 29, 2010 | Dometic Rooftop RV Air Conditioner
My Dometic Rv ac is not cooling but, the fan does run..
Can you give me the model number of your AC unit. There should be a sticker on the bottom of the upper (roof) unit, that you can see when you take the filter down from the ceiling inside. Also need to know if it's a wall thermostat and what brand/model, or are the controls at the ceiling.
Apr 24, 2010 | Dometic Rooftop RV Air Conditioner
Relay (?) sticking Dometic RV rooftop AC
Go up on the roof of the unit and remove the AC Shroud. With the unit running, see if you can pinpoint where the sound is coming from. The only thing on the entire AC that would make that much of a vibration would be the fan motor. Not sure what would cause the fan motor to do this. The compressor may do that but only if the windings are bad and then it would not be cooling.
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
Fan will not come on
maybe the capacitor for fan was already busted try to check that.
May 17, 2009 | Dometic Rooftop RV Air Conditioner
Rv Roof top ac unit
Fan motor bearing getting hot and seizing on the shaft. Just changeout the fan motor...
Aug 30, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
225 people viewed this question
Top Dometic Heating & Cooling Experts
Marvin
Marvin
Sheldon Dedek
Mike
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
