Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
A
Anonymous Posted on Jul 11, 2014
Display flashing all the different languages - Hotpoint Ultima WD72 Front Load Washer/Dryer
Bill Francis
Level 1:
  • Contributor 3 Answers
  • Posted on Aug 20, 2014
Bill Francis
Contributor
Level 1:
Answers
Questions
0
Helped
822
Points
5
It could be roaches got into the motherboard electronics. Remove the display PCB and spray it with an non residue electronics cleaner. Dry thoroughly. Be cautious of static discharge when handling PCB. Touch the case of the appliance then the PCB.
Image flashes for one second on screen then goes away
There could be a few different issues that could cause the behavior you're describing. Here are a few possibilities:
HDMI connection issue: Make sure the HDMI cable is properly connected to both the TV and the laptop. If you're using a HDMI splitter or HDMI switch, make sure those are also properly connected.
HDMI port issue: If you've tried multiple HDMI cables and still have the issue, there could be an issue with the HDMI port on the TV or laptop. You could try a different HDMI port on the TV or laptop, or use a different device to see if the issue persists.
Display settings: Make sure the display settings on the laptop are set to display on the external monitor (the TV in this case). If the laptop is set to display on the built-in monitor, it may cause the display to flash on and off.
Hardware issue: If none of the above solutions help, there could be a hardware issue with the TV or laptop. It's possible that the display controller or other hardware component is faulty and causing the display to flash on and off. In this case, it may be necessary to have the device repaired or replaced.
I hope this helps! If you have any further questions, please don't hesitate to ask.
Why lg_xenon_gr500 does not read arabic?
The company just simply didn't add Arabic language format to the phone. I don't think you can actually flash it to your phone either. The operating system on the phone is simply a basic cell phone with touch screen capability. Nothing more, nothing less.
If you'd like a phone with different language formats on it, I'd recommend you to get an Android phone. You can personalize just about anything on this phone including setting your phone to display Arabic language. There's budget Android phones that work way better than these smart phone knock offs. They are basically made to look like a fancy device. If on contract cell phone companies usually pay the phone for you and give you a phone like this for cheap or even free with a 2 year agreement. There are also budget android phones that are cheap and/or free out there if money is the issue.
Change language settings on laptop
I'm gonna assume you are on windows 7.
(if its a different windows then some actions may differ)
Press Start (windows symbol)
In search box where cursor flashes type LANGUAGE
Go through the four options that appear listed referring to language
"Region and language". click drop down arrow to select a language
If your language is not shown then look for the option to install a language
Giving error information with different character almost like displaying another language
maybe it's viruses. try to clear your flashdrive from viruses. then format it, use only format program from you flash drive manufacture (DON'T USE WINDOWS UTILITIES)
I cantchange the language and i dnt know why everything i touch is not workin
Here is link to the manual:
http://www.curtisint.com/html/custservice/manuals/SYL_SMPK8854_EN.PDF
Language issue::
Abnormal display of file name.(Different language display)
Move to / in the Manual screen and set an
appropriate language
Hope this helps
Need to change Apire 5732z from Spanish laguage to English, kindly assist
To install a different language - Multilingual User Interface (MUI) - you need to have Windows 7 Ultimate.
Anytime Upgrade to Windows 7 Ultimate
Type Anytime Upgrade in the Search programs and files box in the Start menu and click on the Windows Anytime Upgrade icon. From there, you can buy an Anytime Upgrade to Windows 7 Ultimate. Then your can enter your Anytime Upgrade product key and perform a simple upgrade to Windows 7 Ultimate so you can install a different language.
If you are in Australia, Belgium, Canada, France, Germany, Italy, Japan, the Netherlands, Spain, Sweden, Switzerland, the UK, and the US you can use Anytime Upgrade. If not you will need to buy Windows 7 Ultimate, or buy Windows 7 in the language you need.
http://windows.microsoft.com/en-us/windows7/products/windows-anytime-upgrade
Install Language Pack in Windows 7 Ultimate
1. Start -> All Programs --> Windows Update --> Optional Updates.
2. Open optional Updates and go to the section Windows 7 Language Packs.
3. Tick the Language Pack you want and hit OK
4. Proceed with Install Updates
5. Depiction of Windows 7 downloading a Language Pack
6. Automatic install initiated after download
How to change the Windows 7 Display Language:
1. Go to Start -> Control Panel -> Clock, Language, and Region / Change the display language
2. Switch the display language in the Choose a display language dropdown menu.
3. Click OK
4. Log off for the changes to take effect (This will affect only the user profile under which you are currently logged on).
Can you help by identify which folders that contain language
Click on your phone menu, select the settings option, you will see different functions there, click on phone settings, another folder will display, you will see different options, click on the language, different options of language will display on phone screen, select your choice of language and you are on.
Rate this.
Best regards.
1helpful
How do I change the language on my new J4580 machine
Hello
Thank you for using FixYa for your problem.
Try this;
Changing the language on the HP All-in-One displayFollow these steps to change the language on the All-in-One display.
  1. Press the Setup button (c01361401.gif).
  2. Use the arrow buttons (c01185108.jpgc01185072.jpg) to select Basic Settings, and then press OK.
  3. Use the arrow buttons (c01185108.jpgc01185072.jpg) to select Set Language, and then press OK.
  4. Use the arrow buttons (c01185108.jpgc01185072.jpg) to scroll through the language options until the preferred language is displayed.
  5. Press the numbers on the numeric keypad that correspond to the appropriate language displayed on the control panel display.
    NOTE: Ifa selection is not made within five seconds, the display automaticallychanges to show the next language. If a selection is not made withintwo minutes the setup menu exits and the language/region remainsunchanged.
  6. Confirm the language choice.
    • Press the number corresponding to Yes to confirm the selected language.
    • Press the number corresponding to No to select a different language.
  7. Aftera language is selected, a screen is displayed for region selection.Press the numbers on the numeric keypad that correspond to theappropriate region.
    NOTE: Ifa selection is not made within five seconds, the display automaticallychanges to show the next region. If a selection is not made within twominutes the setup menu exits and the language/region remains unchanged.
  8. Confirm the region choice.
    • Press the number corresponding to Yes to confirm the selected region.
    • Press the number corresponding to No to select a different region.
Please Rate my solution or reply for another answer if still not going
Thanks
Richard Scott
Technical Support
1helpful
How to change the langue
Set the display language
In the device options, click Language. In the
Language field, click a language. Click Save.
About the input language
You can set an input language to use when you type.
This setting is different from the display language.
When you set an input language, AutoText and other
typing settings change to the selected language.
Set the input language
In the device options, click Language. In the Input
method field, click a language. Click Save.
Related topics
About the input language (See page 79.)
Set the display language (See page 79.)
Add or remove a display language
If your BlackBerry® Handheld Software supports
multiple languages, you can add and remove
languages using the Application Loader tool in the
BlackBerry Desktop Software. See the BlackBerry
Desktop Software Online Help for more information.
N80
dear,
flash the phone you can change the language pack.
you need to flash it with the EURO version firmware for the whole thing. (different from the PPM language pack for the Series 40
regards,
dont forget to rate it
Aug 15, 2008 • Cell Phones
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
