Question about Quantaray 50mm f/2.8 AF Tech-10 for Canon EOS
It doesn't work with my digital camara
Got this one time ago, but now i bought a digital rebel XTI, and it doesn't work.....
Posted by kikiza on
  • Mariagal Dec 17, 2007
    I have not bought a digital yet but I am seriously thinking about it. I would like to know if the Quataray lense I have will be interchangable with a Canon Rebel XT digital. I now use my Quantaray lense with a Canon Rebel G (35mm film) The Quantaray lense I have is a Tech 10 70-300mm macro
  • Tdaero Jun 16, 2008
    Instantly get an "Error 99" message every time. Looking for answers!
Anonymous
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 216 Answers
Some of the early Quantaray lenses, designed for the EOS film cameras, need to be upgraded by Quantaray. Contact your local Ritz Camera, or go to their support page online to find out if an upgrade chip is available for your particular lens, so it can be used with a digital EOS
Posted on Jul 06, 2008
Canon rebel xti
Tr5y a factory reset on the camera. And try another Memory card.
Aug 19, 2014 | Canon EOS 400D / Rebel XTi Digital Camera
Blurred edges
blurring occurs not depending on ISO, i think the lens is the problem. try to clean the lens glass carefully, is there some grease stick on the lens? if not it might be dislocated one of the lens structure.
have you try another lens?
Jul 26, 2013 | Canon EOS 400D / Rebel XTi Digital Camera
Computer does not recognize my canon eos rebel xti 400D
You can download the driver aand reinstall it from this link: http://www.nodevice.com/driver/EOS_400D/get37008.html Make sure your existing Canon software, if any, is removed before installing the new driver. If this doesn't work you can always purchase a card reader and extract your photos directly from the memory card.
Sep 26, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
How do you get to the video mode on the canon 400d rebel xti
There is no video mode on the Xti. The first Canon Digital Rebel to be equipped with video was the T1i, which came out almost 5 years later (2 years ago).
Feb 15, 2011 | Canon Rebel XTi / EOS 400D (body only)...
Can I set a Canon EOS Rebel XTi up so that the picture I am taking shows up in the LCD?
No. You require a feature called live view and your camera doesn't have it. It's technically difficult to achieve on dSLR's and it's only a couple of years ago that it started to appear on some models.
Oct 08, 2010 | Canon EOS Digital Rebel XTI Digital Camera
I recently bought a used canon EOS 400d which was
Be aware that the built in flash does not pop up automatically in all picture modes. Try it when in the different modes (on the mode dial) and see what I mean. Does it popo up when manually opened ?, (small button on front left hand side of the viewing pentaprism/flash housing.)
Oct 02, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
CANON REBEL XTI LCD
Your battery is low ...shut the camera in off position and replace with fresh battery
Oct 06, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EFS Lens question- please help!!
Make sure that the switch on the lens is set to AF. If that doesn't work, you may have a faulty lens. The EFS 18-55 is not a high quality lens.
Mar 10, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Tamron lens for Xti?
if it is an auto focus lens that works on one eos camera, it should work on almost all of them. the only known exception is that some high end extenders will not fit the eos1dmarkII as it protrudes into the opening too far.
but a good rule is that if it fits without any obstruction issues, it should work. try cleaning contacts on the lens and camera body. if that doesn't fix it, talk to Tamron. you can use it manually, but will not be as easy and you would get less predictable results.
my suggestion is to always go with lens from camera maker.
sounds like there is an issue with the tamron lens. not the camera.
good luck
mark
Dec 16, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Quantaray 50mm f/2.8 AF Tech-10 for Canon EOS Logo
240 people viewed this question
Top Quantaray Cameras Experts
Paul Green
Marvin
Marvin
Harrie
Are you a Quantaray Camera Expert? Answer questions, earn points and help others
